Old Aug 29, 2014, 05:00 AM
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
Dr Mad Thrust chrome 64mm
I just received the new Dr Mad Thrust 64mm edf unit from HK.
http://www.hobbyking.co.uk/hobbyking...4000kv_4S.html
Sadly, I have to report the major problem with this new fan unit is that it is actually a 60mm fan. Only the outer casing diameter is 64mm.
Unfortunately for my application (a Freewing 64mm jet) this is next to useless. The gap is just too big, Freewing jet accepts a true 64mm fan which has an outer casing diameter of approx 67mm.
I am not sure if I'm going to test this unit any further or just sell it on.
I wonder if all the fans in the new HK chrome electroplated range are undersized?
If so, perhaps the 68mm version is a true 64mm fan?
green_flyer is offline Find More Posts by green_flyer
Sold NIB** Dr Mad Thrust 1600kv 2400watt 90mm EDF Inrunner 6s version (36mm) lmpbpd Aircraft - Electric - Jets (FS/W) 4 Nov 05, 2013 09:06 PM
Sold Dr mad thrust edf maccdaddy Aircraft - Electric - Jets (FS/W) 6 Oct 31, 2013 02:07 PM
Sold NEW - Dr. Mad Thrust 90mm 12 Blade Alloy EDF 1000kv - 4200w (10s) bwoollia Aircraft - Electric - Jets (FS/W) 7 Oct 16, 2013 11:57 AM
Question Dr. Mad Thrust Series Motor B2970 p901P901 Electric Ducted Fan Jet Talk 1 Sep 20, 2013 08:09 PM
