Old Jul 29, 2015, 08:08 PM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Help!
Falling out of the sky. It always rolls to the left?
H-King Color 250 quad frame with PDB board
AfroFlight Naze32 Acro AbuseMark FunFly Controller
Turnigy Multistar 6A V2 ESC With BLHeli and OPTO 2-3S
Turnigy Multistar 1704-1900Kv 12 Pole Multi-Rotor Outrunner V2
OrangeRx R110X DSMX/DSM2 Satellite Receiver.
5x3 gws style props (came with frame)
3s 2200mah batteries.
This is my first "real" quad. 60% of the time I can fly with zero problems and everthing is great.
40% of the time it falls out of the sky for absolutely no reason at all as far as I can tell.
It always rolls left when it falls out of the sky. I've swapped receivers from a real spektrum DSM2 receiver to the orangeRX one, and that didn't change anything. Nothing is blinking on ether the Naze or the receiver. battery power is just fine 80%. motors / escs are well under tolerances.
I've been flying RC for 8 years and i'm a developer so I mostly know what i'm doing, but these quads are new to me, and I have zero idea how to go about debugging this. It's infuriating because I can fly out 4 batteries in a row with zero problems one day, then the next it falls out of the sky every 3 minutes.
Help?
creapyd is offline Find More Posts by creapyd
Old Jul 29, 2015, 11:25 PM
rodman99999 is offline
Find More Posts by rodman99999
Joined Feb 2015
Any possibility of interference from a nearby, high-powered Wi-Fi source?
rodman99999 is offline Find More Posts by rodman99999
Old Jul 30, 2015, 12:18 AM
Cereal_Killer is online now
Find More Posts by Cereal_Killer
I void warranties
United States, OH, Columbus
Joined Dec 2014
Dude, get BlackBox, find out FOR SURE what's going on.
Cereal_Killer is online now Find More Posts by Cereal_Killer
Old Jul 30, 2015, 06:54 AM
creapyd is offline
Prefectionist
Joined Mar 2007
No. I've been flying spektrum at this club for 8 years and have never had an interference problem.
Old Jul 30, 2015, 07:31 AM
waltr is online now
Find More Posts by waltr
Team AlienWarpSquad
United States, PA, Doylestown
Joined Jan 2014
The FC's Firmware does a Gyro cal during processor bootup. If you move the copter during the time it is doing the Gyro cal it will not fly properly.
Ensure it is NOT moving or do a manual Gyro Cal with the stick command.
Could be a bad solder joint/connector between ESC and motor.
Could be a bad ESC or a bad motor or the motor mounting screws sometimes touch the motor coils.
Re-check these on the left side.
waltr is online now Find More Posts by waltr
Old Jul 30, 2015, 08:09 AM
Mrimstad is offline
Find More Posts by Mrimstad
Mrimstad's Avatar
Joined Feb 2014
6a esc + 2200mah battery?
Heavy thing with weak esc's?
Mrimstad is offline Find More Posts by Mrimstad
Old Jul 30, 2015, 08:12 AM
creapyd is offline
Prefectionist
Joined Mar 2007
The total amps at full throttle is only about 16amps so about 4amps per ESC. and when it's NOT falling out of the sky it flys very well.
nether the motors or the ESC's are anywhere close to hot.
Old Jul 30, 2015, 08:14 AM
creapyd is offline
Prefectionist
Joined Mar 2007
I should note that my flying buddy has the exact same quad, with the exact same setup and has had zero issues.
Old Jul 30, 2015, 08:26 AM
Mrimstad is offline
Mrimstad's Avatar
Joined Feb 2014
Then thats not your issue.
Discussion Naze32 Mini-Quad suddenly falls out of the sky daneelgiskard Multirotor Electronics 14 Oct 23, 2015 11:39 AM
Discussion My tricopter keeps falling out of the sky! Help! rhys100 Tricopters 0 May 11, 2015 01:36 AM
Discussion Quad falls from sky when yawing left. L bmpire Multirotor Talk 4 Jul 15, 2014 05:51 PM
Discussion First Flight - Falls out of the Sky! TexomaEV Multirotor Talk 37 Dec 27, 2013 03:18 PM
Help! PLEASE HELP, Always rolling left!! Redmist Sailplane Talk 16 May 16, 2011 05:13 PM
