Old Apr 30, 2012, 08:03 AM
Camboui is offline
Find More Posts by Camboui
Brussels
Joined Jan 2011
DSM2 and PPM
I have a Spektrum DX5.
Is there any way to plug a PPM signal in the trainer port from any other tx to control a DSM2 rx ?
I mean, is there a way to use the DX5 as a DSM2 relay for a non DSM2 tx ?
Thanks.
Camboui is offline Find More Posts by Camboui
Old Apr 30, 2012, 09:20 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thanks.
Let's rephrase the question. Can the DX5e transmitter be linked to another transmitter in a buddy box or trainer arrangement? The DX5e would serve as the master transmitter.
Answer: YES, probably. But you'll have to be specific about the type of the second transmitter. With Spektrum or JR, it's easy. You just need a Spektrum trainer cable.
With other transmitters, you will need a special cable. Tell us the details.
By the way, this has nothing to do with DSM2. The other transmitter could be an old AM or FM.
Daedalus66 is offline Find More Posts by Daedalus66
Old Apr 30, 2012, 09:21 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, just use the DX5e as a master trainer.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 30, 2012, 09:50 AM
Camboui is offline
Brussels
Joined Jan 2011
Okay, you see what I'd like to do
A Futaba tx would be the slave and the DX5 the master. Actually the master DX5 sticks should never take ownership, only its DSM2 protocol sent to the air is needed.
If this works it would be a way to replace those Spektrum DM8 modules not any more made.
So, you think a simple mono-jack 3.5mm cable joining both trainer ports would work ?
Old Apr 30, 2012, 11:48 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Not simply with a Futaba Tx....the trainer port isn't a 3.5mm socket and the channel ordering is different e.g. Throttle is Ch1 Spektrum and Ch3 Futaba.
Steve
slipstick is online now Find More Posts by slipstick
Old May 01, 2012, 01:37 AM
Camboui is offline
Brussels
Joined Jan 2011
Ah yes indeed, Futaba trainer port isn't 3.5mm, a cord has to be made. Ch order isn't important as master tx wouldn't be used.
Other than that, you think it should work, without electrical or PPM signal issues ?
Thanks.
Old May 01, 2012, 02:39 AM
Staffs, UK
Joined Nov 2003
The PPM signals are basically identical so the only other potential problem I can think of it that Futaba signals are about 9V, ground referenced whereas Spektrum signals are about 3V and floating....but the overvoltage shouldn't hurt and a simple capacitor in the signal lead should take care of the ground referencing.
But I haven't actually tried it, I'm just going on what was needed in Futaba to JR trainer conversion circuits, so you will need to experiment....carefully.
Steve
Old May 02, 2012, 06:27 AM
Camboui is offline
Brussels
Joined Jan 2011
Thanks a lot slipstick.
I did a name mixup, sorry. I own a HP6DSM, not a DX5 (mind getting old yet ?)
The trainer connector is not the same but removing 2 cables from inside the HP6DSM seems to make it act as a Specktrum/JR trainer. Still need to do and test.
Aside, I could check a buddy box with a DX6i as master and Turnigy9X as slave. It works as is (without the 9X resistor fix, module removed).
Thanks for the Futaba voltage warning. Any source to look at for the Futaba to JR conversion circuits ? That could help a lot.
Old May 02, 2012, 08:04 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
Horizon does have a Futaba to JR Trainer Cord. I have seen a Futaba transmitter used as a Buddy Box for a DX7.
Buschbarber is offline Find More Posts by Buschbarber
Sold 2 - JR XP7202 transmitters PPM/DSM2 hammer22 Aircraft - General - Radio Equipment (FS/W) 1 Oct 19, 2011 08:23 AM
Sold 2 - JR XP7202H Transmitters PPM/DSM2 hammer22 Aircraft - Electric - Airplanes (FS/W) 0 Oct 17, 2011 06:48 PM
Discussion Getting PPM output from a Spektrum RX without any PPM stage Arthur P. DIY Electronics 44 Apr 26, 2010 04:38 AM
Discussion 4 channel servo in to PPM out converter to Conect a DSM2 recever to a Mirokopter jamesatwork DIY Electronics 9 Mar 01, 2009 10:12 AM
Sold JR FM Module for PPM / PPM (NET-J72P) wamdue Aircraft - General - Radio Equipment (FS/W) 0 Oct 18, 2005 12:30 PM
