Old Mar 23, 2015, 09:48 AM
Joined Feb 2015
JR XG14 Full 14CH
hi,
i'm about to get this radio and was just wondering if its possible to get the full 14Ch without using Xbus at all. is it possible to bind two 7ch receivers to the xg14?
thanks, ido.
ido100 is offline Find More Posts by ido100
Old Mar 24, 2015, 08:37 PM
Joined Oct 2005
Xbus is the way to do it. With 14 servos you might need it for power distribution. What are you trying to do?
If you use xbus you can have more that 14 servos if you do things like multiple servos on a surface.
mlachow is offline Find More Posts by mlachow
Old Mar 24, 2015, 11:17 PM
Joined Dec 2011
At least it's senselessly, both Rx will have 1-7ch channels mapping. Without support at Rx you can't get 8-14ch channels mapping. But Xbus always carry all possible Tx channels.
vlad_vy is offline Find More Posts by vlad_vy
Old Mar 25, 2015, 05:43 AM
Joined Feb 2015
I'm not trying to do anything, just curious.
Thanks for the answers.
And if I'm using xbus, can I use channel 8 with xbus or I need the zero channel receiver?
Old Mar 25, 2015, 08:07 AM
Joined Dec 2011
Any XBus Rx has all possible Tx channels at XBus.
Old Mar 25, 2015, 10:38 PM
Joined Oct 2005
Any channel can be assigned to xbus adapter or servo independent of the dedicated channels on the rx.
So if you had two elevator servos, you could connect both to an xbus adapter and run just one cable back to the tail.
Xbus does require some programming to assign channels to adapters or xbus capable servos. You can also set reversing and centers and travels on xbus. The reason for that is you can have up to 4 servos on a channel so that us where you adjust each servo.
News XG14 DMSS System - JR Americas Jim T. Graham Radios 335 Mar 25, 2015 08:21 PM
Review JR XG14 14 CH DMSS Transmitter With JR X BUS Review Michael Heer Radios 42 Mar 05, 2015 12:41 PM
Sold JR XG14 14ch DMSS System w/RG1131B Rx ibcinyourc.com Aircraft - General - Radio Equipment (FS/W) 0 Oct 29, 2014 11:33 AM
Sold JR XG14 14CH DMSS System w/ JR RG1131B 11CH RX & JR Dual Transmitter Case NIB spookyeng Aircraft - General - Radio Equipment (FS/W) 1 Apr 15, 2014 11:52 AM
New Product New JR XG14 DMSS E-Keith Radios 21 Jul 12, 2013 07:31 PM
