Old Nov 30, 2014, 02:35 PM
Joined Aug 2006
Help!
Error indication on my CC Phoenix ICE 100
Hello,
could you help me figure out what is going on with my ESC?
When I connect the battery I get the initialization beeps, but right after that a yellow LED lights up. When I move the throttle up a red LED starts to blink in addition to the steady yellow LED, and the motor beeps twice about every 3 seconds, but no spinning.
Could you tell me what all these indications mean?
Many thanks.
jackheli is offline Find More Posts by jackheli
Old Nov 30, 2014, 04:31 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Did you train the ESC to the throttle range of your receiver?
From the manual:
2 beeps and flashes - Low Voltage Cutoff:
Your batteries are likely discharged. Check that batteries are fully charged and that Phoenix detects the proper number of cells at power-up.
Beep Codes/Conditions
All Castle ESCs will sound a single beep every 20 seconds to remind the user that the controller is connected to a battery and drawing power. Leaving a controller connected to a battery for extended periods will likely damage the battery.
Red LED
• Blinks out cell-counts /error codes
• Flashes a little at low throttle
• Flashes a lot at high throttle
• Solid on at full-throttle
• Pulses quickly when governor-mode is locked
Yellow LED - used for Data Logging (Phoenix Ice, Phoenix Ice Lite and Phoenix Ice2 HV only)
• Yellow LED flashes when logging, and is on continuously when log is full.
Wintr is online now Find More Posts by Wintr
Old Nov 30, 2014, 06:31 PM
A man with too many toys
United States
Joined Feb 2001
Power up the ICE at full throttle will clear the data log. Then lower the throttle trim and it will arm. Some flybarless controllers won't allow you to start up at full throttle. For those you have to use the Castle Link to clear the data log.
The Edge series has improved hardware and does not have this problem.
RC Man is online now Find More Posts by RC Man
Old Dec 02, 2014, 12:21 PM
Joined Aug 2006
Got it!
Many thanks. Appreciated.
Discussion Error indication on my CC Phoenix ICE 100 jackheli Power Systems 1 Nov 28, 2014 07:22 AM
Sold CC ice 100 CC edge 100 lore2486 Aircraft - Electric - Power Systems (FS/W) 3 Nov 05, 2014 03:22 PM
Discussion Phoenix Ice 100 - Error Occured While Parsing the Logged data mxracer33x Castle Creations 5 Jul 19, 2014 03:04 PM
Sold Step right Up - Worlds Ugliest ESC CC Phoenix ICE 100 Whopper Chopper Aircraft - Electric - Power Systems (FS/W) 1 Mar 06, 2014 01:07 PM
Sold CC Phoenix ICE Lite 100 ESC - NIB! tewatson Aircraft - Electric - Power Systems (FS/W) 0 Oct 23, 2013 12:29 AM
