Old Aug 25, 2014, 09:29 PM
New York
Joined Feb 2002
Question
LET DG-1000 Retract Wheel
Just noticed that the retract tire on my Let DG-1000 has split. Somehow I recall that Let uses CB Associate giant scale wheels. The tire measures a shade over 4" in diameter and CB carries a wheel that looks identical to the one supplied by Let.
Here is the link to CB Associates: http://www.mecoa.com/cb/wheels.htm
Does anyone know for sure if the CB wheel does the job?
TIA,
Steve
SteveR is online now Find More Posts by SteveR
Old Aug 25, 2014, 10:00 PM
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Yes they do. You may need to re-bush the axle, but you can always use the guts from the one you have.
Len
Lbuff1 is online now Find More Posts by Lbuff1
Old Aug 25, 2014, 11:28 PM
New York
Joined Feb 2002
Steve
Old Sep 07, 2014, 05:51 AM
alvaro corzo's Avatar
United States, CA, San Diego
Joined Feb 2006
It
Originally Posted by SteveR View Post
Steve
Let uses cb as their wheel supplier, so does FEMA and Hock.
alvaro corzo is offline Find More Posts by alvaro corzo
Old Sep 07, 2014, 08:03 AM
New York
Joined Feb 2002
Thanks Alvaro. When I ordered a replacement wheel from CB, I also ordered one directly from Let which arrived one day after I installed the new CB wheel. Apparently Let now sources locally as their hub is machined aluminum and the tire compound is somewhat harder than CB. Either one should do the job nicely.
Also, I believe Hock is no longer in business though FEMA definitely is along with a few new German retract suppliers including:
http://www.dr-martin-thoma.com/trias-fahrwerk.html
They make this fantastic retract.
Steve
Old Sep 07, 2014, 01:41 PM
United States, CO, Delta
Joined Aug 2011
Wow! That is a sweet system,thank you for Posting Steve. Paul
dufek paul is offline Find More Posts by dufek paul
Old Sep 07, 2014, 10:22 PM
Joined Jul 2009
[QUOTE=SteveR;29378009]Thanks Alvaro. When I ordered a replacement wheel from CB, I also ordered one directly from Let which arrived one day after I installed the new CB wheel. Apparently Let now sources locally as their hub is machined aluminum and the tire compound is somewhat harder than CB. Either one should do the job nicely.
I notice CB offers the larger (5") wheels in both smooth and rib-treaded types . Are both used on the full-scale sailplanes? For a 6-8m scale sailplane ( Nimbus4), would either have an advantage, or is it cosmetic? Thanks, Bob
flyingfever is offline Find More Posts by flyingfever
Old Sep 07, 2014, 10:37 PM
New York
Joined Feb 2002
I think CB offers its smooth and treaded wheels just as Dubro and other do to reflect the full size ship be it a sailplane or power plane.
Steve
Old Sep 07, 2014, 10:48 PM
Joined Jul 2009
Steve
Thanks, I just didn't know the difference. So, the smooth is used on the sailplanes. Smooth it will be. Thanks.
Old Sep 08, 2014, 07:21 AM
New York
Joined Feb 2002
I'm not suggesting that sailplanes always use smooth tires, just that both styles are available from suppliers, both R/C and full size.
Steve
Old Oct 26, 2014, 04:02 PM
Joined Oct 2010
Alvaro please send me my wing back you have had it and my money for 10 months!
If anybody can get a message to Alvaro he has the wing center sectioned my Satori and $250 for the last 10 months and will not respond to my emails,
tulsasailplane1 is offline Find More Posts by tulsasailplane1
Discussion Let DG-1000 SteveR Scale Sailplanes 10 Jul 21, 2014 02:11 PM
Discussion Let dg-1000 SteveR Scale Sailplanes 13 May 14, 2014 08:44 AM
Discussion Modifying 2.6 meter DG 1000 for retract and spoilers. daveb572 Scale Sailplanes 6 Nov 23, 2013 04:43 PM
Video Mike Lance DG-1000 landing at Torrey Pines 9-21-13 Phil Davy Scale Sailplanes 21 Sep 30, 2013 02:59 PM
For Sale Let DG 1000 Seat Pan Set. alvaro corzo Aircraft - Sailplanes (FS/W) 0 Sep 21, 2007 08:35 AM
