Old Mar 09, 2013, 05:21 PM
pounditracing's Avatar
Joined Jan 2013
9oz flying weight motor suggestions.
Hey guys, I'm building an outdoor 3d flat foam plane. It will be running a 20amp esc on 3 cells. Total weight is just under 9oz. My current motor is way to much so I'm searching for a new one but don't really understand all the KV and watt talk. Please help!
pounditracing is offline Find More Posts by pounditracing
Old Mar 09, 2013, 06:12 PM
micka80ella's Avatar
Australia, QLD
Joined Apr 2012
http://adamone.rchomepage.com/
Use the wing loading page to calculate your stall speed to then allow you to choose a motor prop combo.
Or post up all the dimensions of the plane and its dry weight and we could have a fiddle with the online calcs to give you an idea.
micka80ella is offline Find More Posts by micka80ella
Old Mar 12, 2013, 05:06 PM
Joined Jan 2013
Calculate Wing Loading, Area & Stall Speed
Wingspan: inches 26
Wing Root Chord: inches 7
Wing Tip Chord: inches5.5
Or the Average Chord: inches 6.3
Or the Wing Area: sq.in 163.8
Model Weight: ounces 8
Max Lift Coefficient:
WING LOADING: oz/sq.ft 7.3
g/sq.dm
CUBIC LOADING: oz/cu.ft. 6.59
STALL SPEED: mph 13.1
I'm not sure if that is what you were looking for but that is what I get when I put the numbers in.
Old Mar 12, 2013, 10:00 PM
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
I like the hobby king 24 gr hextronik 1500 kv motor on my 8 oz scratch built FoMoJo 30
FoMoJo30 maiden (7 min 51 sec)
gatorb8 is online now Find More Posts by gatorb8
Latest blog entry: FPV 250 Cruiser Quad
Old Mar 13, 2013, 01:33 AM
Livermore, CA
Joined Sep 2004
I run the 1300kv 24g Bluewonder from HobbyKing on a couple dozen planes and the 1500/1700Kv as well.
It powers my 10-13ozs planes with better than one to one thrust, about 14ozs of thrust on a 3 cell.
So for a 9oz plane, it should have enough power to do lots of 3D.
Butch777 is offline Find More Posts by Butch777
Discussion Dji f450 weight for fpv flying WATTS2005 Multirotor Talk 1 Apr 21, 2013 02:56 AM
Discussion Need Suggestion on motors! abriosi Multirotor Talk 5 Jan 12, 2013 03:36 PM
Wanted motor for 35-67oz flying weight Doushiyou12 Aircraft - Electric - Power Systems (FS/W) 1 Mar 26, 2011 04:24 AM
Discussion Flying Weight / Lift / Motor Correlation jmendell FPV Talk 10 May 23, 2007 08:14 PM
Discussion Motor suggestion for light weight 150W DD PFTrvlr Power Systems 1 Mar 14, 2006 04:29 PM
