Old May 14, 2014, 04:25 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
Keyrigger,
In regards to aerobatics and helicopters. In my early scale days I used to do all kinds of crazy stunts like barrel rolls, backward hurricanes, inverted pitch pumps, flips and rolls on my 450 scaler, it was fun and if it wrecked it no big deal; I was out only a few hundred bucks tops. When I moved up to the 500 size scaler (MB-7) I started cutting back on some maneuvers, like no inverted anything; partially due to my skills going full scale and not practicing 3D anymore (you don't use it, you lose it) and also because the extra $$$ tied in the machine; Other factors like flexible scale blades, even lower headspeed... I kept on doing backward hurricanes and vertical stall turns, but none of the insanity I did on the 450.
Then once I built the 600 (MB-8) in 2010 I did cut on anything that had any risk associated with it, besides forward flight with banked turns; skill deterioration after 1 1/2 years without flying any 3D took its toll; that coupled with the 6+ grand $$$ and 6+ months of work tied on the 8 pretty much left the MB-8 as a scale hoverer and a grandpa taxi and now it will fulfill its true destiny, become an FPV scale platform.
G.
Minibichus is offline Find More Posts by Minibichus
Old May 14, 2014, 07:22 PM
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
With this particular body, I was not worried about the crash factor at all. It had survived a few dirt naps and although a bit worse for the wear, it was still very much a solid body. The major weakness was the plywood floor because of the additional weight that was put on it between the formers, not over them. I fixed that in the rebuild where I put in all new wood and it has held up very, very well. The landing gear is the second item that is way too weak for the average chassis installed in there and that problem has been fixed for good. The gear will now take a hard landing and with the structural change to the body, the entire body is more resilient to abuse because of autorotation landings. I collapsed three struts because of that so it is nice to not need to cringe as much anymore.
Now about the aerobatics, I felt that it was not going to get me what I thought it might. When maneuvers are done that are not standard, eyebrows tend to get raised a LOT. I have proof that both the AS350 and my TOW Defender can be pushed into loops and rolls like any other mildly aerobatic aircraft. The difficulty is getting it past the nay-sayers. I will be limiting the moves to lazy 8's, hammerhead turns, pedal turns, and high angle landing approaches. There will be no way of arguing the helicopter's ability to do those. The last thing is that like a full size helicopter pilot that bought the farm, this helicopter, when held too long nose down in the loop, will stall when pulling out and pancake into the ground. Four times I have been high enough to be able to power out of that pending disaster and I figure I have used up all my horseshoes with that helicopter for good. This is a good a time to stop as any, lol. I will not stop pushing myself to fly as if I was in the cockpit and put on a flying show as interesting as watching an aerobatic biplane. Funny part is that I just did some 3D testing a chassis and found I could now hover inverted better than I had before. I do need to get my 450Pro out and continue to keep practised with it but if I don't get it out this year, I will not loose sleep over it. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old May 14, 2014, 08:29 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
Very nice.
In my experience the weakest part of the 500 heli fuselages has been the canopy. If you plunge into the ground hard enough it will come off and get chewed up by the rotor blades. When I built the 8 I designed everything on the landing gear to withstand a 5 feet fall; then, while testing the NAZA a wrong feedback loop on the collective proved the design when slamming full collective-down into the asphalt with only a few scratches. Now, I didn't have the canopy on at that time, but I am certain would've been the canopy installed, I would've had to order a new one; and I have like 10 neo-magnets holding the dang thing, and it still pops out if you are not careful.
Inverted is out of the question for me as I never learnt anything beyond basic flips and rolls; even then, if I knew and was good at it, the MB-8A has roughly 5-7 degrees of coning at the rotor head; that seems like a sure way for a boom strike, should I attempt any high negative G maneuver. Maybe loops might be fine provided you keep the rotor always loaded positively...
I understand the nay-sayers will always be nay-sayers but whatever, right? But.. your heli looks great, flies great so who cares what others say so long you are happy with it. I was usually the only scale flyer at my previous club's field, and ppl hated the 20+ minute flights because they thought me flying was a waste opf time; they wanted to practice 3D around the clock, which wasn't a waste of time. I am sure if it would've been anyone doing piroflips and other interesting 3d stuff, the 20 minute flights would've not been a problem at all. Thats part of the reason why I got out of the hobby for a while. I was tired of the 3d stick bangers just hating. The new club I am now part of, the 3d stick bangers are the minority, as most pilots fly large scale fixed wing aircraft, therefore the MB-8 is now right at home, and around a lot of ppl who respect and like scale stuff. I no longer have to prove to anybody I can piroflip the MB-8...
G.
Don
Old May 15, 2014, 11:55 AM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
Jesse Kavros 3D'ing a scale Hughes 500E (Mikado Logo 600) (3 min 48 sec)
Old May 15, 2014, 01:00 PM
Keyrigger's Avatar
Joined Sep 2009
I've seen this done a number of times by different pilots and it doesn't do anything for me. My own opinion is that it is done to make fun of the work done by so many scale builders and when those builders are asked to do such crap with their scale builds, those that ask walk away with a lesser opinion of the piloting skills of those fellows. If you want to do scale, do it. If you want to do 3D, do it. However, do it with the appropriate helicopter. Even one of my club members did this with the same setup as in that video but as usual, destruction did follow. His reason for flying 3D with it is that it infuriates some of the club members when he does it so he would rather do 3D with it than learn the skills to fly it as if it was a full size. The shame of it is that this is all he does with it and I honestly don't even watch him fly it. Scale aerobatics that can be done by the original helicopter are fine and add some real excitement to a scale flight but tick-tocks, rainbows, and inverted flying should be left in the parking lot. If you put enough power into an MI-26, you can get it to do a loop, too, but what is the point?
Don
Old May 15, 2014, 01:21 PM
MB-Commander
Minibichus's Avatar
Joined Feb 2008
I have to agree; but I must admit its cool to see someone with the skill to do it, but then it just looks silly after a while. Now, I wasn't aware of such opinion to make fun of scale builders, but whatever, its their money: scale 3D you better have the pro-skills to back it up, otherwise, your crashes will be 5 times the time and cost of wrecking a pod/boom.
One of the things I take pride now when I go to the field is teaching people who want to fly scale how to setup their gear for proper scale flight. I met the other a guy loved seeing my next build (a larger heli than the MB-8) and quietly asked me for some help. Upon looking at the setup I was told it was done by someone who exclusively flies 3D.... a 3D setup to fly scale... I was like WTH??? 100% throttle curves, with headspeeds that would cut trees... pitch curves that made no-sense for a scale flight, and let alone for learning hovering. He just wanted his pod/boom to fly similar to how my heli flew. So, we sat down and I explained to him some of the basics and after some tuning, we got his heli flying similar to how any of my helis flies: he loved it, and he thought it was a lot easier to fly too (he is learning to hover)
Keyrigger, to me you don't have to prove anything man, I love what you've done with your helis, and the fact you take pride with it thats all it matters. When I started flying scale back in 2009 I was a hot-head, due to coming from a strong 3D background and I felt I had to prove myself I could outfly anyone in scale, but once I grew up (keyword here) I realized the point of scale is not to show off your flying skills... in fact, the smoother you fly the more people tend to like it so I concentrated in learning smooth precision scale flight, forgetting altogether the 3D school from where I originally came from.
Now I just want do my thing man: doing slow circles with my large scale helicopter, when I have the NAZA fully tested FPV too... but I am sure someone thinks is dumb too, since anyone can buy a cheap quad and do it. The feel of seeing a large scale helicopter over the road with nav lights, makes you feel like the real deal is up there!!
I am not sure if this is some sort of statement, but maturity level indicates what kind of flying you do... b/c lets face it... if someone has the motor skills to build a scale helicopter with the amount o details you've into yours, I am 100% sure he can also become a phenomenal 3D flyer as well: but motivation is just no there, and we all know motivation is the fuel to drive progress.
G.
Don
Old Aug 04, 2014, 09:17 PM
Keyrigger's Avatar
Joined Sep 2009
The Boys are Back in Town
Over the past month, I have been thinking hard about going to either the AMA US Nationals or to IRCHA. I guess I could have done both but that is for another time. I don't have a single "Scale" build done and before you say that I already have scale helicopters, I really don't. The three large helicopters that I have are all fictitious as they are not based on an actual helicopter model in that colour and markings. That is the main reason I am building the new Jet Ranger and 500MD TOW Defender bodies. I am going to be entering in Sport Scale which only requires a 3-view drawing and a modellers declaration so it is not quite the same as the full blown class. Next year, yes, this year, no.
So it was time to dig up some bits from the crash and get Bruce back in place, large and in charge. I went over the body from one end to the other repairing paint chips, scratches, and finishing off some new parts that had, as yet, not been painted. A bit of weathering was added to the new head and landing gear as well as the exhaust. I was at a float fly-in this past weekend and was not comfortable flying a non-float equipped aircraft there so the AS350 and 500MD TD sat in the truck. When I went to paint the head, I discovered that one ball link on the grip was two threads from coming off. You could see where the thread lock was and that really bugged me but it might have been my own doing as I found two others that were not hard tight but still had thread lock holding them in place. It must have been that I didn't torque them in as I usually do so something must have dragged me away just before tightening them up. Had I gone to a Warbird event on Sunday, it would have had a serious dirt nap. So here are the pictures that I did and had a bit of fun with. The third figure is the pilot from the rebuild and he is having words with the confiscating flight crew but Bruce is not even paying a bit of attention to it, lol. Take care and maybe see some of you at IRCHA.
Don
Old Aug 05, 2014, 06:42 AM
AMA#313760
JLogan's Avatar
United States, MI, Taylor
Joined May 2009
Don
Don,
I sometimes do aerobatics with my scale helicopters, but not to piss someone off but to show some of the 3d guys that scale flying can be as tuff as their style of flying. When I land I tell them to add 25 lbs. to their 700's and then do their 3d I get no takers. The other point I make is a lot of the 3d guys tell new RC pilots and to everyone that scale helicopters are something you fly once in awhile but not every day. I say BS. I fly mine every day I can. Flying scale can be just as tuff and unforgiving as 3D. New pilots just getting into the RC helicopters need to see this so they are not turned off by the 3D guys and to have a open mind about scale. If you look around there are few RC helicopter pilots and a lot less scale RC Helicopter pilots at AMA fields.
John
JLogan is offline Find More Posts by JLogan
Old Aug 05, 2014, 03:19 PM
Joined Jul 2008
Originally Posted by JLogan View Post
Don,
John
+1 - scale are helis that are flown regularly by many, including guys I know who also fly 3D.
rotoraddict is online now Find More Posts by rotoraddict
Old Aug 05, 2014, 04:41 PM
AMA#313760
JLogan's Avatar
Joined May 2009
Where I'm at we our out numbered on a good day 60 to 1( Or More) over fixed wing. Most AMA Fields around here, are geared to fixed wing. I fly both myself so your right about that.
John
Build Log Another T-rex 600e and Century MD500 TOW build thread (IAF Defender) ScaleBrad Scale Helicopters 69 Feb 23, 2014 06:18 PM
For Sale Hughes MD500 Defender Fuselage - $40 Jumpjet101 Aircraft - General - Miscellaneous (FS/W) 0 Oct 26, 2012 08:50 PM
Sold Century MD500 fuse (.90 size) baldwinc Aircraft - Electric - Helis (FS/W) 0 Aug 14, 2012 10:31 AM
For Sale Scale 450 size MD500 Defender LPU Dallas Area lwright292 Aircraft - Electric - Helis (FS/W) 6 Mar 29, 2012 03:27 PM
For Sale MD500 Defender body kit for Raptor 60 czechyour6 Aircraft - Fuel - Helis (FS/W) 2 Feb 13, 2006 09:04 PM
