Old Sep 01, 2011, 07:43 PM
Strongbow's Avatar
Jacksonville, Fl.
Joined Jan 2010
Hey ARCTURAS just a heads up. When installing your T-pro, position it so the spline shaft is oriented towards the tail. The control rods for this bird are a little short. Moving the servo around will give you more adjustment for trimming and still provide the extra throw the elevator needs. Have fun.
Strongbow is offline Find More Posts by Strongbow
Old Sep 01, 2011, 09:48 PM
USA, FL, Doral
Joined Jul 2006
Originally Posted by Arcturus97 View Post
Hello All,
I've read all 1300 or so posts over the last two weeks. I pulled the trigger on a PNP Meteor from Nitroplanes late last week; its arriving tomorrow. I've also got one 4S-3300-30C Sky lipo, one 5S-3000-30C Sky Lipo, and a T-Pro MG servo for the elevator coming from Hobbypartz as well. This is my first EDF so I wanted to start out with 4S but also have option to try 5S. Looking forward to getting it together and its maiden flight.
For benefit of anyone who hasn't read all 1300 posts here is my summary of what stuck in my head, in no particular order
  • Most are happy with the performance of the Meteor, fun to fly
  • Many on this thread consider the Meteor a better value than the Habu
  • Make clearance for enough elevator throw, use outer hole in servo horn
  • Consider a replacement metal gear servo for elevator
  • Make sure fan & motor are centered and balanced
  • Make sure all the control horns are glued securely as well as other fasteners
  • Stock Habu (4S) is faster than Stock Meteor (4S)
  • Stock setup can handle 5S (unlike Habu)
  • Stock Meteor on 5S is faster than Stock Habu (4S)
  • Current Draw on 5S is in the high 50s
  • Current draw on 4S in the 40s amp range
  • Speeds: Stock setup 4S in the mid 80s mph; mid to high 90s and even 100+ on 5S with stock setup; level passes
  • ESC in Meteor stays cooler than Habu due to location, even on 5S
  • Poor packing materials from Dynam can result in damaged airframe during shipping
  • Sources in US are Nitroplanes and Grayson
  • Seems like most people use batteries between 2650-3300 mah, though plenty of reports up to 4000, 5000, or as low as 2200
  • Adjust your battery location with the smaller or larger batteries to maintain proper CG, may require cutting some foam
  • Retracts are doable but weight penalty
  • Hand launches are possible, so are bungee launches
  • Options available for aftermarket fans & motors
  • Careful on landings, keep up enough speed to avoid stall, adjust with rudder vice ailerons once on final
  • A guy named Pavcon had to wait 3 months for his Meteor, then it was busted up some on arrival. Sorry dude
I'm sure I'm missing plenty...
There is a chance you will fry the stock ESC with 5s lipos...It happened to me.
yucafrita is offline Find More Posts by yucafrita
Old Sep 01, 2011, 10:04 PM
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
Thanks for the tip Strongbow
Arcturus97 is offline Find More Posts by Arcturus97
Strongbow's Avatar
Jacksonville, Fl.
Joined Jan 2010
Must have been a bad esc. I fly mine for a solid 5 minutes on 5s. Battery and esc dont even get warm.
Old Sep 04, 2011, 02:17 AM
Joined Sep 2011
Wing skids
Anyone hand-launching the Meteor using any kind of skids for the underpart of the wing? I was thinking of getting the Evader wing skids and put them on. Any ideas?
elteto89 is offline Find More Posts by elteto89
Old Sep 04, 2011, 08:46 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Skids to protect the wing during landing?
link?
thx
Melnic is offline Find More Posts by Melnic
Old Sep 04, 2011, 12:18 PM
Joined Sep 2011
link?
thx
GP's Evader Wing Skids:
http://pics.towerhobbies.com/imagel/g/lgpma2887.jpg
http://pics.towerhobbies.com/imagel/g/lgpma2881.jpg
http://www.electrifly.com/ductedfans...0-3view-lg.jpg
As you see they are bigger/taller than the average wing skids (http://www3.towerhobbies.com/cgi-bin...?&I=LXTDS6&P=7). I wonder if they would work well on the Meteor.
I just don't want to hurt the plane too much with scratches on landings. It would be neat to keep it as clean as possible
I ordered them last night but Labor day is coming so no skids for like a week I'll keep you guys posted.
Old Sep 05, 2011, 11:57 PM
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I was flying my planes yesterday in pretty heavy wind.
On some i had to use spoilers to avoid forcing them down. I tried the same with meteor and the effect was opposite: ailerons in up position worked like elevons. This gave me an idea for better elevator authority. I put a mix of elevator to ailerons and now at full speed I can do a loop almost as small as with my extra.
And this applies to inverted too, which until now was scary and done at 5 miles up.
Another thing worked is harrier and almost a hover and I am using a brick for a battery. (4s 5000 mAh turnigy)
While I was in programming mode I added to my throttle kill switch (mix 1) full spoilers and full down elevator to cut down on landing roll. Once I touch the runway I flick my mix switch and plane stops rolling in about 15-20 feet.
I also put front gear servo on gear channel, separated from rudder, but mixed with it so I can trim both independently.
I put on the plane 8 flights since and love it.
Rob
robusp is offline Find More Posts by robusp
Latest blog entry: Pulsar 3.2E Competition Pro
Old Sep 06, 2011, 12:02 AM
United States, OH, Cleveland
Joined Feb 2010
Got to maiden my Meteor this weekend... Flies good. Lots of fun.
The only question I have is
With my 4s 3000 battery all the way forward in the tray it still seemed like it was tail heavy.
At least I think that was what I was feeling. The plane kept wanting to climb, and took ALLOT of down trim for level flight.
Landing was GREAT.... I see many more touch-n-goes in my future
D.
dmize is offline Find More Posts by dmize
Old Sep 06, 2011, 05:45 AM
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
WELL .............Mr rorrock RC wares
Global Hobby Store
WHERES MY TWO METEORS WHICH WERE PAID FOR ON THE FIRST OF AUGUST ????
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Sep 06, 2011, 06:44 AM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
seems that its not just my problem.. Expect 2 damaged planes just like mine arrived
pavcon is offline Find More Posts by pavcon
Old Sep 06, 2011, 06:56 AM
Joined Nov 2002
Some of these dealers should be reported for extortion....this is really SLACK
Old Sep 06, 2011, 07:18 AM
Joined Jan 2010
and ofcourse he's not interested in replacing any of these parts.. one is for sure.. my plane won't fly ok
Old Sep 06, 2011, 07:29 AM
Joined Nov 2002
I guess you pay your money and have to take your chances....but not the way it should be...All I hope is that no one deals with him again
Old Sep 06, 2011, 09:05 AM
Joined Jan 2010
definetely not me...
Sold Larry Jolly "Meteor"-127" Kit NIB --Now $275 Shipped ldm1839 Aircraft - Sailplanes (FS/W) 5 Sep 29, 2010 06:34 PM
Discussion Meteor shower tonite, You goonna stay up for it? Bilbobaker Life, The Universe, and Politics 13 Aug 16, 2010 12:32 AM
Build Log Peter Rake's 30" General Western Meteor Prototype dz1sfb Scale Kit/Scratch Built 19 Aug 15, 2010 11:38 PM
Discussion Two Hours Outside and I only Saw One Perseid Meteor Chophop Life, The Universe, and Politics 12 Aug 12, 2010 08:28 PM
For Sale Russ Thompson Meteor fuse Bill L Aircraft - Sailplanes (FS/W) 0 Oct 15, 2009 10:18 PM
