Old Nov 12, 2014, 01:25 PM
Joined Feb 2012
Will these ESCs be ok?
Ztw 20a mantis esc's. Took the wires off so I can solder the motor leads directly to the esc. Was so much solder though, it looks a bit messy. I cleaned it up as much as possible, but I'm still concerned.
Take a look and let me know.
JGrn is offline Find More Posts by JGrn
Joined Feb 2012
Old Nov 12, 2014, 01:26 PM
Joined Feb 2012
Old Nov 12, 2014, 01:27 PM
Joined Feb 2012
Joined Feb 2012
Old Nov 12, 2014, 01:45 PM
holtneil's Avatar
United Kingdom, England, Central Bedfordshire
Joined Dec 2012
Hi mate do your self a favor buy a de-solder pump they are not a lot of money, and then heat solder once solder is hot use the pump to suck off solder so it will be a clean contact , on some of the pics there is a chance of the solder running on to 2 contacts and short out
holtneil is online now Find More Posts by holtneil
Old Nov 12, 2014, 01:54 PM
Joined Feb 2012
The three contacts on each esc are totally separated. What concerns me is the chip on the board, behind the contact, some of the solder touched the contact and the solder on that chip. If you look close you'll see what I mean. I bought solder wick but it didn't do a great job.
I don't know if it's ok for the solder on the chip and the solder on the contact to touch.
Discussion will these servos be ok? microairman1 Scratchbuilt Indoor and Micro Models 6 Oct 13, 2014 06:57 PM
Discussion First build, will these parts work together and how long will the flight time be? willwills90 Multirotor Talk 2 Apr 21, 2014 08:47 AM
Discussion Would these motors be ok? djhand2 Multirotor Talk 0 Oct 17, 2013 03:14 PM
Discussion Will these blades be ok hunterz Fuel Heli Talk 2 Jul 12, 2007 02:31 AM
will these batteries be ok? flybike Power Systems 2 Feb 23, 2002 09:15 PM
