This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Apr 22, 2015, 12:50 AM
adamtoo is online now
Find More Posts by adamtoo
Sweden, Norrbotten County, Luleå
Joined Sep 2014
i'm not sure but the answer might be because some planes have no rudder.
Originally Posted by unknownflier View Post
When in 2DHH and the G drops one wing to counter-act the yaw it senses, doesn't the aircraft lose height/altitude as a result of dropping a wing? Why doesn't the G use rudder input to correct yaw? I'm semi-sure the answer is simple and because I never use 2 (anything) mode I am not snapping to what it is.
Still curious though.
thanks,
uf
adamtoo is online now Find More Posts by adamtoo
Old Apr 22, 2015, 12:56 AM
unknownflier is offline
Find More Posts by unknownflier
you-know-me ...
unknownflier's Avatar
United States, CA, Redlands
Joined Jul 2013
Like my F-22. See, I knew the forest was there. Damn trees.
UPDATE - Page 7 v1.1 manual, G does use the rudder in 2D HH, along with the ailerons. If no rudder then ailerons only. If no ailerons then elevons.
unknownflier is offline Find More Posts by unknownflier
Old Apr 22, 2015, 03:30 AM
farrari is offline
Find More Posts by farrari
Australia, NSW, Balgowlah Heights
Joined May 2013
wheres CHOOCHOO when he is needed. Again all 2D modes self level.
farrari is offline Find More Posts by farrari
Old Apr 22, 2015, 12:15 PM
IGIVEUP1 is offline
Find More Posts by IGIVEUP1
Out of the Past
Canada, BC, Vernon
Joined Aug 2014
Does no one recall setting " LEVEL" in the initial setup. Yes! 2D HH self levels. HH is still 2D but holds a heading using aileron and elevator.
IGIVEUP1 is offline Find More Posts by IGIVEUP1
Old Apr 22, 2015, 02:14 PM
Joined Sep 2014
Thanks for the clarification everyone. I was just confused and apparently scoffed at earlier for suggesting that 2DH did self level
Old Apr 22, 2015, 03:01 PM
John M63 is offline
Find More Posts by John M63
Sioux Falls, SD
Joined May 2006
Guardian and a G62 gasser
Hi all, after our newer club members demonstrated the Guardian 2D/3D one of my fellow club members and I ordered a G. After repeated review of the instructions and 2/3 days of reviewing this thread I managed to complete the installation and somewhat understand the operation of the G.
While I was reviewing this thread I noticed that most of the aircraft were electrically powered. I then search the thread for gas power aircraft and found that vibration from gas engines may induce unwanted performance like destroying the G
My test gasser is a Giant Ugly Stick powered by a Zenoah G62 turning a 22X10 prop. I am using a JR 9303 TX and JR 921 RX.
I had originally installed the G with Velcro on a platform mounted to the side of the fuselage. I am now trying to come up with a new mounting solution. I have some packing material, not foam, but a sponge like material. I could cut a piece to fit in the fuselage side to side. Then cut a slot to place the G and put a small piece of tape to secure it to the packing material. I know without identifying the specifications on the packing material, it is like asking ‘how high is up.’
I read Rick’s current setup instructions and the section which he describes the “suspended platform” and gel pads. Those are good solutions and I will investigate.
I am wondering if any of the thread readers have experience with large gas engines and the G and could offer suggestions.
O and by the way I have decided not to use the G in my 1/3 scale L5 W/106 cc engine.
Thanks for reading.
John
John M63 is offline Find More Posts by John M63
Old Apr 23, 2015, 03:24 PM
ogg2000 is offline
Find More Posts by ogg2000
Joined Jun 2013
Take a look at pages 687 and 688 of this thread. I've shown the two options I use based on the original idea by prof100 to used weights on a compliant mount to reduce the effects of vibration.
Prof100 shows his original solution on page 688.
As far as I can tell the G is immune to vibrations with either of these set ups. Obviously the DZ160 vibration is very reduced due to the AV mount. Its a beast and would kill a light airframe if solidly mounted.
Dave
ogg2000 is offline Find More Posts by ogg2000
Old Apr 23, 2015, 11:54 PM
you-know-me ...
Joined Jul 2013
Elevator has no bearing on azimuth control, on self leveling, yes
Per page 7 of the v1.1 (Choochoo22's) manual
[QUOTE]
2D with HH self levels when the sticks are centered and holds an azimuth. This is useful as described above.
2D without HH is the same but doesn’t hold an azimuth. This is useful for pilots who like to use rudder control on landings for example, as HH will oppose your rudder inputs.
[END QUOTE]
Old Yesterday, 06:53 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
2DHH will oppose rudder input because it uses ailerons NOT rudder to control azimuth. If you use rudder to line up to runway for landing the g won't see it as a stick input and will counter with ailerons to try to correct. This is why 2DHH isn't really the best option for landing....
DamonH is offline Find More Posts by DamonH
Old Yesterday, 08:00 AM
you-know-me ...
Joined Jul 2013
You are correct. I'm so used to controlling heading/azimuth with the rudder or a combination of rudder and aileron that when I read "will oppose rudder inputs" the first thing I think of is because it's using the rudder to control azimuth like when a c/w blows your tail around. but nope, it clearly says so under2D w/out HH. Good thing I handcatch and don't try to land in 2D HH, that would be a real show.
Old Yesterday, 09:19 AM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
If the nose rises or falls when the ailerons adjust for azimuth, the elevator will compensate, to keep the aircraft level, fore/aft.
Wintr is offline Find More Posts by Wintr
Old Yesterday, 10:35 PM
John M63 is offline
Sioux Falls, SD
Joined May 2006
Dave
Thanks Dave, I reviewed the pages you suggested and I plan to use them as a backup solution. I will use the foam as a vibration damper. It is difficult to explain the properties (for me) but (I think they will work (well, I hope they will work.)
I will provide pictures when the installations is finished.
Again many thanks for your input.
John
Old Today, 12:57 AM
you-know-me ...
Joined Jul 2013
@ wintr,
You said:
"to keep the aircraft level"
YES, the elevator is keeping the a/c level, whether it's caused by wind, ailerons ... or whatever.
The elevator can only control something pertaining to the vertical plane or pitch axis. It has no input value in controlling the azimuth contrary to what the earlier poster said. It is merely correcting a problem with the attitude caused by the ailerons.If the elevator was disconnected and the ailerons corrected for the azimuth and the elevator did not correct the attitude, the aircraft would still be back on the correct azimuth irregardless of whether it was nose up or nose down.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
