Old Jul 05, 2014, 11:23 AM
Joined Jul 2014
Blade 200 QX FPV
I had been out of the rc world for awhile and got back into it with the purchase of a Blade 350 QX. Then the bug hit again and I bought a 200 QX and decided to modify it to FPV. I had to move the battery to the outside to make room for the Fatshark parts, so I used a Blade CX2 battery cage and screwed it onto the body. I then moved all the blade electronics to the bottom of the body where the battery normally sits, and then put the fatshark parts on top. Because I wanted to paint it, I moved the LED's so you can see them during flight.
Here are a few pics of the build.
Dutch_K9 is offline Find More Posts by Dutch_K9
Old Aug 17, 2014, 12:25 PM
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
Nicely done.. Some of the pics are not coming through though. Are you running the fatshark off the same battery or are you running a separate batt?
I plan to do similar
joshgluck is online now Find More Posts by joshgluck
Old Aug 19, 2014, 12:55 PM
Joined Nov 2006
I love that setup. I just bought the 200qx. Which fatshark did you get?
supac is offline Find More Posts by supac
Discussion 200 QX BL ( BLH7780) BNF With SAFE™ Technology by Blade® crave Multirotor Talk 4 Jun 17, 2014 11:12 AM
Sold Blade 350 QX / 200 QX - USB-Interface - Multi Rotor Programmer - BLH7840 Fidelity101 Aircraft - Electric - Multirotor (FS/W) 1 May 31, 2014 01:21 PM
