Old Aug 04, 2014, 10:06 AM
chuck
santa barbara, CA
Joined May 2009
Originally Posted by dahawk47 View Post
Tried mine today. Might have an esc issue. Swapped the stock 40 amp with a Hurc 60. Used a 2700 mah 4S 30C. Seemed grossly underpowered.
motor started hesitating so I brought her down.
Would a 56mm hyperflow from my retired GP F-20 work in this plane. ?
imo , no.......... not well anyway. the beauty of this plane is its 70mm fan in a smaller airframe.
chas650r is offline Find More Posts by chas650r
Old Aug 04, 2014, 10:08 AM
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Thanks GTX,
Are there two versions of this plane? A 3S and a 4S ? I do have a 64mm 4S motor fan/combo I can use.
Yes, the HURC ( Headsup rc) esc is programmable. Not sure which timing setting is recommended though. Low,med, high. I can also simply do an esc reset. The stock 40 amp esc will not cut it on 4S.
dahawk47 is offline Find More Posts by dahawk47
Old Aug 04, 2014, 10:27 AM
Augermeister
dahawk47's Avatar
Joined Jul 2011
It's a 70mm? Well slap me on the @$$ and call me Sally ! LOL
I have one of those in the hangar as well.
Old Aug 04, 2014, 05:52 PM
chuck
santa barbara, CA
Joined May 2009
it's a killer w/ a mid power c/s 10blade and the tv .
Old Aug 05, 2014, 06:19 PM
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by 62pilot View Post
Got some color on my baby. Sure helps orientation.
That looks great!
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Jan 2014
Old Aug 06, 2014, 07:24 AM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Well figured build one for a test and if it works then go for one for speed.
Picked up the foam and canopy kits to build one. Incorporated many of the tips I picked up here.
Thanks to all.
List of mods.
Fully glassed.
Extended intake.
Airflow dam on the belly.
Skid tape on the bottom of the intake.
Flexible flaps over the hinge lines.
Intake lower glassed, intake upper has plastic insert with esc cooling cut out.
Fan moved back further.
Mylar exhaust tube.
Clear plastic deflectors in front of the servos.
CS 70mm 10 blade.
Turnigy 2100 kv motor.
Plush 100 amp esc.
6S3000 pack, two 3S in series.
Model Master yellow into a faded orange into red for looks on top. Black and white stripes on the bottom.
And painted the canopy black on the inside.
Sunk a pair of 1/4" lite ply blocks in place of the stock canopy latches, pair of screws hold the canopy down.
Must of done something right, the packs sit dead center in the cockpit, so have room to play with different packs.
Excuse the tanks, I build those for a client. They are fully r/c, 1/6th scale.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Aug 06, 2014, 09:27 PM
Augermeister
dahawk47's Avatar
Joined Jul 2011
Glacier,
Looks great ! I'm still sorting out my Squall that I rescued from the bin. Stuffed a 10 blade CS with a FW motor from my retired F4 Phantom. I did notice that when I ran up the throttle, the elevons twitched a bit. Could the exhaust flow cause the thrust vectoring linkage to move on it's own ?
Have a 60 amp esc installed but a bit concerned that it's not enough. Would feel more comfortable with a plush 70 but I hate taking the fuse apart. The previous owner had epoxied it in place. Took some surgery.
Ready to test.
Old Aug 15, 2014, 12:09 AM
littlemisterbig's Avatar
Joined Aug 2014
Glacier Girl,
How exactly did you glass it? Did you sand the paint of first and did you prime it with anything? Also is standard resin safe for foam?
littlemisterbig is offline Find More Posts by littlemisterbig
Old Aug 16, 2014, 09:58 PM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Thanks to all.
List of mods.
Fully glassed.
Extended intake.
Mylar exhaust tube.
CS 70mm 10 blade.
Plush 100 amp esc.
ok.....let's see some vid of this bad boy flying !!!
KCinNC is offline Find More Posts by KCinNC
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
