Old Yesterday, 10:44 PM
RC Adddict
Wilfor's Avatar
150 mile house B.C. Canada
Joined Jan 2010
Originally Posted by Shadrack View Post
So just use an inverter and hook it up to a 3S 5100 for example?
Need some help from the geniuses on here.
Have a lightbridge. Want an HDMI monitor to hook up to it that I can take with easily and have a lipo for.
checked a bunch today that had either 14v or 19v external power supplies.
Can I feed 12 to the 14 and be ok, or should I go to a 4S pack and am I okay at 16 with 14 as the draw?
What do you guys suggest. Have 3S and 4S packs.
Looks like BC has you covered. Once i move up to a light bridge an inverter and one of those 12v powerpacks for boosting your vehicle is what I was going to use. Bonus is you can charge your lipos off the owner pack as well.
I want a nice high def tv but got to make sure it works well out in the sun unlike my PC screens and iPad
3drobotics is hoping to have competition for the light bridge in the next little while apparently.
Wilfor is offline Find More Posts by Wilfor
Old Yesterday, 10:49 PM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
You'll both be able to fly using both 1258 and 1280. they are far enough apart to work. Just dont have one vtx beside the other's rx. A fm video signal needs only 18 mhz bandwidth.
Martin Y is offline Find More Posts by Martin Y
Latest blog entry: Flyfly Fox Glider
Old Yesterday, 10:52 PM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
I read one the 'Lab that we might get stepped on if one plane is a lot further away than the other one though.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Yesterday, 10:59 PM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
Once your both a couple of hundred meters you should be ok. Unless one is way lower in power. If one aircraft is 200 meters away from the gs's and the other 20 then yea it can bleed over to the others rx.
would be even better if we can find passband filters for each channels we fly, but were stuck using
comtech rx's.
Old Today, 12:38 AM
Shadrack's Avatar
Winnipeg
Joined Feb 2002
yeah std inverter for auto battery on a big 3S lipo would work great if you can't find a DC LEDTV.
But if it says it runs on 16-18V, then just use a 4S battery, no inverter, no regulator.
Ones I found were 14V and 19V.
Shadrack is online now Find More Posts by Shadrack
Old Today, 12:41 AM
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I was so impressed tonight. Some of the DJI stuff is not for the faint of heart. Guys in here no problem but you move from one piece of software to map, one to check direction, etc. Wouldn't wish the A2 and full DJI system on a rookie.
Made my brain hurt a few times but to have the video from the BMPCC come out perfect tonight, and have my son on the operator controls was pretty neat.
The product is so well made though, across the board.
Now just have to get into color grading.
Yay.
Old Today, 02:05 AM
fly by night
Joined Sep 2011
so the 14 volt one should be fine with 4S, which runs 14.8V to 16.8V. Might want 5S for the 19 volt one. Doubt they are fussy about voltage, though if you want to be sure, put a buck converter (aka regulator) on it like this one: (has a nifty in/out voltmeter to make life even easier and monitor your battery too) http://www.ebay.ca/itm/DC-DC-Buck-St...c163994&_uhb=1 though this might be barely enough amps to handle a large LED, would be fine for a small one I think (2amps max)
Can't always be sure about voltage. My Boscam vRx can't be trusted over 12.5 volts. I was going to run my jump-pack into the ground station but the lead acid battery is like 14.5V when its charged, so that is a no go without regulator.
I just put a $0.99 buck converter in my GS to run 5V into my DVR a few minutes ago
Old Today, 02:32 AM
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Sydenham
Joined Jan 2012
this ones a good one also http://www.ebay.ca/itm/400515865193
i've been getting things from hong kong faster than china lately 5-10 days over china's 15-30
I really like these ones tho
http://www.ebay.ca/itm/141352971191
irun4fundotca is offline Find More Posts by irun4fundotca
Old Today, 05:30 AM
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
BC, the really Important part is that you don't land near each others ground stations. Land a couple hundred feet away and unplug the vtx out there before bringing it back.
Tracks is online now Find More Posts by Tracks
Old Today, 08:59 AM
Canada, BC, Kamloops
Joined Jan 2011
The Selfie is Dead introducing the Dronie !
Have you guys seen this one...pretty funny...what next?
http://www.telegraph.co.uk/travel/sn...he-dronie.html
HuskyDude is online now Find More Posts by HuskyDude
For Sale Skylark EH-1 old n5ktt Aircraft - Electric - Helis (FS/W) 2 Mar 24, 2012 05:49 PM
Discussion Canadian-ized ....eh micro_doc Foamies (Kits) 1 Oct 28, 2011 11:30 AM
Discussion Eh, eh, eh. 5KW 123 pack dusty IV Batteries and Chargers 6 Dec 31, 2008 06:58 PM
Eh any other Canadian Micro Heli's out there? HBirdV.2 Micro Helis 13 Jul 27, 2004 11:38 PM
What does EH stand for in this pack? [N-600AA (EH)] Skysaurus Electric Plane Talk 1 Nov 27, 2001 10:41 AM
