Old Sep 26, 2014, 07:07 PM
AlfaXray1's Avatar
Joined May 2011
Considering 2 metal gear small servos, one for each wing and y connector.....I'll run some tests to see if they swing under load. My original 40" Span F-14 would not even though I had put a 114 oz.in servo in it. With the big swing pin and the short moment arm It would bind, and It was binding to the top cover also. So I had to go negative "g" and near zero airspeed to make it swing.....I want to avoid that on this one. So I am increasing the leverage moment and making a carbon fiber swing pin. After I get all this convoluted stuff in place I will post some photos.
AlfaXray1 is online now Find More Posts by AlfaXray1
Latest blog entry: Warbirds
Old Sep 26, 2014, 07:16 PM
AlfaXray1's Avatar
Joined May 2011
Here are a couple of ideas for paint scheme....these 2 squadrons were on the U.S.S. John F. Kennedy when I was on there. So I reminiscing back a few years.
Old Sep 26, 2014, 10:17 PM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Decrease the STICKY with Packing tape or something slipperyer.
birdofplay is offline Find More Posts by birdofplay
Old Oct 23, 2014, 01:00 PM
Go ahead... Build it to crash!
Fuegodeth's Avatar
Conroe, TX
Joined Apr 2007
Hello all,
I'm nearly finished with my build. Had to post a couple of pics.
Fuegodeth is offline Find More Posts by Fuegodeth
Old Oct 23, 2014, 01:59 PM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
That will be a fun flier.
I see you added a top side stiffener.
NOT a bad addition :-)
must have videos ! ? :-)
Old Oct 23, 2014, 04:46 PM
Fuegodeth's Avatar
Conroe, TX
Joined Apr 2007
No videos done yet.
Still got a little more work to do on the LED's, as it will be a night flyer, and I've got to put a little bit of color on it. I'm hoping to have the maiden flight done by this weekend. I'll try and remember to do some video when I'm out there. I usually get too excited about flying and forget to pull out the camera.
The stiffener on the top is actually 1mm x 6mm carbon going all the way through the top sheet. It's the same as on the wings. It's what I had on hand. It works very well with 6mm depron though, as it's the same thickness. I guess most people use some carbon rod on the underside of the top sheet. It's basically the same result, but it shows through on top.
So far the AUW is 16oz with a 3s1000mah pack in place.
I have 3 EXI 9g digital mg servos,
a 25A turnigy plush controller
a rewound ax2210 motor. Not sure of exact kv, but it pulls about 15 to 16A at full throttle with a 7x5 prop.
I think it should go pretty well. It's not quite as light as some that have been in this thread though. There are red and white LED's in the nacelles. I'm going to add some in the nose section, and have some on top of the plane as well. It should be nicely visible in the night sky.
I'm guessing that after some trim sheets are used for color, and the LED's are all installed that it will be right about 16.5 ounces flying weight.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 02:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 09:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 07:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 09:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 02:48 PM
