AC-10 EPO Gyrocopter
Interesting foam autogyro
Try Something Different
Autogyros are different from the norm and that's why we love them. There are so many different types of craft to play with that it may be impossible to try them all. If Gyrocopters are intriguing to you then check out the AC-10. This gyrocopter uses EPO foam on the outside to give it its unique look. On the inside is a laser cut plywood and aluminum main frame that supports the electronics and mechanics. The rotor head is supported with ball bearings and you get carbon rotor blades in the box as well as metal gear servos to control control the head. The AC-10 is a plug and play unit that includes everything you need except a radio system and a 4S ~3000mAH battery.
Check out the AC-10 Gyrocopter at HobbyKing.
Specs:
  • Rotor Diameter: 1320mm
  • Length: 940mm
  • Height: 690mm
  • Weight: 2200g
  • Motor: 4250 Outrunner
  • ESC: 60A
  • Max Battery Dimensions: 140x43x30mm
Old Nov 19, 2014, 01:44 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
clean design
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Nice Pic
Old Nov 20, 2014, 09:31 AM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
it's nice!
muscleflex is offline Find More Posts by muscleflex
Old Nov 20, 2014, 03:58 PM
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Doesn't the full size have an open cockpit?
killickb is offline Find More Posts by killickb
Old Nov 21, 2014, 11:12 AM
SagittaXC
Soquel CA.
Joined Feb 2007
Confused on price?
I clicked on the link and found the price $ 2,639.00 is that a typo? Its EPO foam right? Jack T.
jacktrotter is offline Find More Posts by jacktrotter
Old Nov 21, 2014, 02:00 PM
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Check your currency, you are looking at Honk Kong dollars, not US Dollars
Old Nov 21, 2014, 02:07 PM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
so what is that in us dollars?
Old Nov 21, 2014, 03:55 PM
roidspop's Avatar
Joined Apr 2005
I looked just now and found a price of $340.
roidspop is offline Find More Posts by roidspop
Old Nov 21, 2014, 04:15 PM
Joined Oct 2009
$315 when you login to your account.
BTW there's already 2 or 3 threads kicking around for this one..
nighthawk0077 is online now Find More Posts by nighthawk0077
Sold Dynamite Passport Ultra DUO AC/DC 400W / 10 amp charger redcaliber Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 11, 2014 03:27 PM
