Old Sep 02, 2014, 11:02 AM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Thanx Flight test
I've been doing the V44 for F&T for years.
Bob
Hoosier Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Oct 02, 2014, 10:46 AM
Philippines, Central Luzon, Marilao
Joined Jun 2008
Hi guys any pics or details on the tilting mechanism?
rukie is offline Find More Posts by rukie
Old Nov 09, 2014, 01:48 AM
United States, CA, Ukiah
Joined Jan 2011
8 degree tilt
Can anyone explain why the motors are tilted towards each other 8 degrees in hover?
devinvagt is offline Find More Posts by devinvagt
Old Nov 09, 2014, 02:37 PM
RCvertt's Avatar
Joined Aug 2007
It uses a well known NASA technique called "cattywampus construction" where each piece of the aircraft is purposely slightly out of faze creating a synergistic harmonics in the airframe that assists with lift by cancelling out unwanted forces. In other words, it's like that because it's made out of foam and tape.
RCvertt is offline Find More Posts by RCvertt
Latest blog entry: Chupacabra sighting !!!
Old Nov 09, 2014, 07:03 PM
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
I'm dying of laughter, RCvertt... Ahahahah however your diagnostics of my airframe design is pretty spot on!
foam and tape is offline Find More Posts by foam and tape
Old Nov 09, 2014, 07:14 PM
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
It actually isn't to far off Rcvertt ,, the real V uses bidirectional carbon fiber to do away with unwanted harmoics .... and actually on the real V it used about 4 degrees of out nacelle angle for stability purposes.
I used by directional plywood sub frame in the NASA Puffin to eliminate wing vibrations
v22chap is offline Find More Posts by v22chap
Old Nov 09, 2014, 07:38 PM
RCvertt's Avatar
Joined Aug 2007
Good to know. I'm a devout follower of "foam and tape's" building methods
Old Nov 10, 2014, 06:25 AM
If you plan on using the nacelle tilt to control pitch, then you definitely don't want the tilt axis to be canted inward. It would reduce the distance between the tilt axis and the CG.
As for the fore/aft tilt, it helps a bit with pitch stability in slow forward flight, and depending on the direction of rotation of the rotors it improves yaw control in a hover.
Brandano is offline Find More Posts by Brandano
Old Nov 11, 2014, 07:44 AM
aeronaughtycal
Joined Nov 2014
amzaing thread ..... i was planning on building a vtol myself for the past couple of weeks but after watching you guys i am more determined to build one .... i am sure i can count on you guys for help
aeronaughtycal is offline Find More Posts by aeronaughtycal
Build Log Quad Tilt Rotor - Build Log (Comments & Suggestions Welcome) maxvtol VTOLs 254 Aug 31, 2014 01:53 AM
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 01:15 AM
Discussion Help selecting receivers and transmitters for quad rotor oscioscia Multirotor Talk 5 Sep 06, 2011 02:43 PM
Discussion mcx 5in1 Unit for Roll Tilt Compensation on Quad nicnaimless Multirotor Talk 0 Aug 11, 2010 02:17 PM
Cool WOW!!!! Iphone controlled quad with vid link to iphone, tilt controlled!! helifrek Multirotor Talk 8 Jan 18, 2010 10:23 AM
