Old Oct 17, 2014, 03:07 PM
Virginia
Joined Jul 2008
Help!
Turnigy Neutron 200W charger
Ordered a couple of the Bolt batteries. In a description somewhere, I believe I read that standard chargers don't charge correctly to take full advantage of the Bolt's available high discharge rate. In the Neutron description, I believe I read this charger exploits the Bolt's full capabilities. Well, I can't get the charger to work. I plug in a 4S 3450 mAh Bolt battery and I get "Cell vol low!" error message. There may be a setting I need to do, but the instructions seem to indicate it's a plug-and-play charger. Any ideas?
BTW my standard chargers charge and discharge the batteries just fine.
agran1021 is offline Find More Posts by agran1021
Old Oct 22, 2014, 02:33 PM
Virginia
Joined Jul 2008
Well, five days and no one from Hobby King has checked in. Decided to do something I should have done before purchasing this charger. Read the reviews for yourself. Short answer is that my problem is widespread. Simply put, the charger does not work according to the overwhelming majority of the reviews. Stupid me: read views, THEN order. Don't purchase and then read reviews.
Old Nov 08, 2014, 02:31 PM
demineur's Avatar
Belgium
Joined Jun 2012
Hello,
This is not "plug and play" charger, you have to indicate cell number and Amp you want to charge.
It is also possible to save the parameters under 10 memories.
I just received my Neutron and it works very well, as well for standard Li++ as for all other batteries types.
PS: I also found the same message when I tried to discharger (just to test) and I noted I was on the wrong cells number for the tested battery.
I hope it will help you.
Have a great day,
/Démi.
demineur is offline Find More Posts by demineur
New Product Turnigy A-6-10 200W Balance charger & discharger CrashingDutchman Batteries and Chargers 70 May 13, 2014 07:45 AM
Discussion Similar or Better 200w Charger than Turnigy A-6-10 ? ruben00 Batteries and Chargers 8 May 22, 2011 04:31 PM
Sold Two Turnigy A-6-10 200W Chargers Available Lardog Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 23, 2011 07:16 AM
Discussion Turnigy Accucel-8 150w or Hobbyking Eco-6 200w charger Howemd Batteries and Chargers 16 Nov 13, 2010 12:47 AM
Discussion Turnigy A-6-10 200W Ballance Charger/Discharger question. green_one Batteries and Chargers 10 Jun 18, 2010 04:40 PM
