Old Aug 17, 2013, 07:24 AM
Saudi Arabia, Makkah Province, Jeddah
Joined Mar 2009
Help!
Help in Hitec Aurora 9 training mode..
Hello everybody,
I am really want to get a help because i am trying continuously,reading and searching..
THE COMBINATION ARE:
i have Hitec aurora 9 and turnigy 9x with built in FrSky DIY V8HT module 2.4Ghz .
the receiver is Delta 8 multi-protocol :
http://www.hobbyking.com/hobbyking/s...dProduct=42310
NOTE : the aurora 9 bound very successfully with this RX....
what is a symptom:
when trying to use both TXs in training mode the Turnigy 9x V8HT not receiving/takes any data/controls from the Aurora 9 ...
The procedure i sued in training is :
1-Make sure the Master(aurora 9) in bound successfully to the receiver. And the batteries is charged..
2- I make sure both TX are the same setting/programming instead the Master set the setting of training (i set the H switch for training as in the manual).
2-Switch ON the master TX and confirm transmitting , then plug a stereo 3.2mm jack in it then in the turnigy (it switch on automatically)and i never switch on the switch.
3-The master is work with the RX but when activating and holding the H switch the Turnigy 9x not getting any respond.
When i searched for this problem they says i should install 1K Resistor in the turnigy 9x ...and i install it before doing the procedure of course ...
I dont know why now the turnigy is not responding ????
I appreciate any idea,suggestion and help..
Best Regards
Nobel0 is offline Find More Posts by Nobel0
Old Aug 17, 2013, 05:21 PM
Joined Aug 2002
Originally Posted by Nobel0 View Post
Hello everybody,
NOTE : the aurora 9 bound very successfully with this RX....what is a symptom:
I appreciate any idea,suggestion and help..Best Regards
Please refer to:
Hitec Aurora 9 - Trainer / Buddy system Master & Slave function Set-up. - & Data Transfer A9<>A9 etc.
- Also covers Eclipse 7 Pro & other Hitec RCD transmitters.
especially section 9:
"09. Hitec TX as Master with Flysky 9 (aka Turnigy TGY 9X, Eurgle 9 & Imax 9X) as Slave only
. How to with Wiring Diagram"
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry,
- FAQ, Setups & Tips
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Aug 18, 2013, 12:08 AM
Joined Mar 2009
Originally Posted by A.T. View Post
Please refer to:
Alan T.
Thank you very much Mr.Alan T for your respond ..
i will check that and post a reply on it ...
thank you very much..
Best Regards
Old Aug 18, 2013, 09:48 AM
Joined Mar 2009
Hello Mr.Alan T again,
I did what is in the link about wiring diagram and also the best solution for RF module which is putting the 1K resistor..
I will show what i did by video please tell me if it is wrong (sorry i dont have nuch english word ) :
Problem of trainer mode with Aurora 9 and Turnigy 9x.. (6 min 21 sec)
but unfortunately it is not fixed.. could you please help me ..
Best Regards
Old Aug 19, 2013, 06:48 AM
Joined Mar 2009
Hello again guys,
i finally solve the problem but BY using the wireless training method..
To use it you should have two RX.
Firls RX will bound in the slave TX and connected in the Master TX.
The other RX will bind to the master which is for the model plane.
NOTE: The two RX not should be have Multi-protocol ..
then, the RX which bind on the Slave should have CPPM (like my delta 8 RX) and then put a jumper on the 3+4channels and bind it .
then you can use the CPPM on the Ch1 AS MY RX.
thank you.
Hope these informations help you ..
Best Regards
For Sale HITEC Aurora 9 Transmitter TX - with Programming Card - Optima 9 RECEIVER! FlySkyVideo - Ecibob Aircraft - General - Radio Equipment (FS/W) 14 Apr 24, 2013 09:33 AM
Sold RX - Hitec Aurora 9 - MINT - TX - Optima 9 - Programming Card - MINT FlySkyVideo - Ecibob Aircraft - General - Radio Equipment (FS/W) 2 Jan 29, 2013 05:20 PM
For Sale HITEC Aurora 9 Transmitter TX - with Programming Card - Optima 9 RECEIVER! FlySkyVideo - Ecibob Aircraft - General - Radio Equipment (FS/W) 2 Jan 22, 2013 03:39 PM
Discussion Brand new Aurora 9 Mode 1 to Mode 2 conversion attempt and fail help mahd Hitec/Multiplex USA 5 Jan 21, 2013 08:05 AM
Help! Hitec Aurora 9 DLG launch mode RJPIoW Radios 3 Jan 31, 2012 10:45 AM
