Old Apr 10, 2014, 06:42 AM
Joined Jun 2013
i'm having trouble with Ft007. Seem it can't BIND . Led on RX flash very quickly then flash slow. I don't see document about BIND , so i can not connect transmiter and receiver
anyone can give recomend for me about this problem ?
John michel is online now Find More Posts by John michel
Old Apr 10, 2014, 11:38 AM
Joined Jul 2013
So great, so fast. Very nice review. Your boat runs fast.
dangquang kdc is online now Find More Posts by dangquang kdc
Old Apr 10, 2014, 01:28 PM
Joined Apr 2014
Ft007
6100 is way to high a kv. 3500is just about right. Props that come with 007 are 4 pitch and a higher pitch of 6 will get it on plane. I'm putting this in 1 posting. Jan showed a cooling jacket and a brush cooling for tabs. I wish those .cooling jackets had a better view ( picture ).
Whiteout is offline Find More Posts by Whiteout
Old Apr 10, 2014, 08:53 PM
Big 3D
jamin's Avatar
Lufkin, TX
Joined Feb 2003
First jumper the safety. Then plug in battery and turn on tx within 2 sec.
Helps to have a helper
jamin is offline Find More Posts by jamin
Old Apr 10, 2014, 09:21 PM
cbtdi's Avatar
New Zealand, Wellington, Wellington City
Joined Apr 2014
Prop tuning
Hi guys,
One modification I've found from LRP is on the prop which will improve the ability to get up to speed and plane quicker. I've done this and can confirm a preformance gain.
Check it out below:
LRP
cbtdi is offline Find More Posts by cbtdi
Old Apr 11, 2014, 10:05 AM
Joined Apr 2014
Ft007
What your doing is bending to increase the pitch of blade. Also what is diameter of inside of prop? OSE has carbon fiber props in the 6 pitch x 29mm or even 31mm but with factory motor, it may get hot if not cooled. Also with carbon fiber props in the 31mm, you could sand down the tips to 30mm and go from there. I would appreciate an answer on factory prop id as I broke my hip 6 weeks ago and shop is in basement and not allowed down steps for awhile, thanks.
Old Apr 12, 2014, 02:15 AM
cbtdi's Avatar
Joined Apr 2014
Hi Whiteout, not sure on the diameter of inside of prop as I don't have any vernier calipers to measure with. Someone else might be able to help here... also, haven't noticed the motor heating up more than normal so it still seems to be in the zone after the tweak
Question Need vital stats on Zoom w/ Himax 4200 8t vs. 9t Fishstyx Mini Helis 8 Sep 06, 2004 10:29 AM
Here's a vital controller question........ HankF Kontronik 2 Jul 21, 2004 04:38 AM
Here's a vital controller question.... HankF Castle Creations 1 Jul 20, 2004 02:53 PM
Formosa vitals? dstrout Parkflyers 2 Mar 17, 2004 12:53 PM
Organic vitals Janusz Jawien Electric Sailplanes 6 Sep 08, 2002 11:11 AM
