Old Apr 11, 2014, 08:09 PM
Too many numbers
United States, OH, Troy
Joined Oct 2010
It works! The trick is to not connect the battery when you zero out the PID and PWM settings. Once I did that, it was cake. This is with the r161 software. Unfortunately I am not coordinated enough to move the gimbal around the camera, but you can see that it works. I noticed from the video that the roll can be a touch slow. To fix that, do you increase P or I?
HobbyKing medium sized gimbal test with $38 controller (0 min 25 sec)
c131frdave is offline Find More Posts by c131frdave
Old Apr 13, 2014, 09:09 PM
Joined Mar 2009
Originally Posted by dslack67 View Post
That could be a ton of different things. One thing I did wrong on my first try putting together my first RC-Timer gimbal and controller was I mounted the IMU wrong way. The thing just jittered and studdered, etc. I mucked with the PID's for hours, "balanced the gopro" a bunch, thinking I just needed to tune it.
I was wrong. IMU was mounted wrong. Swapped in around the correct way, then voila.
This isn't the same gimbal, this is no name inexpensive gimbal running martinez board, modified to front mount on my quad, but the results are fairly good. :-)
http://youtu.be/rlzDUipYfPI
Stunning results! This is a 2 axis unit, yes?
Level Flight is offline Find More Posts by Level Flight
Old Apr 17, 2014, 10:36 AM
Joined Jan 2014
Is there any place where you can buy the controller for the opengimbal software ??
Breezz is offline Find More Posts by Breezz
Old Apr 17, 2014, 10:44 AM
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Sydenham
Joined Jan 2012
$29 and up depending on where you want it from
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
any Martinez gimbal controller will do
irun4fundotca is online now Find More Posts by irun4fundotca
Discussion The OSRC Project - Open Source Remote Control mdem Australia 16 Aug 02, 2013 08:40 AM
Discussion A true open source TX call to arms skripo Radios 28 Jul 14, 2013 02:25 AM
Help! DIY Brushless motor gimbal, need help sourcing parts for gimbal hexa Multirotor Talk 13 Apr 13, 2013 03:08 PM
Discussion Open Source Electric car kit dll932 Life, The Universe, and Politics 0 Jan 21, 2013 09:09 PM
For Sale HackHD 1080p Open Source Camera Ecibob FPV Equipment (FS/W) 1 Jan 17, 2013 11:04 AM
