Old Jun 19, 2013, 02:21 AM
con244's Avatar
Australia, SA, Clarence Park
Joined Apr 2008
Hi just picked up one of these babies. Its my first quad and I was wondering if anyone is using er9X like me? I have it on my transmitter and am using a Spectrum Tx Module. I am not sure how to set this up, can anyone help me with a step by step set up? Or can you post your set up file?
Much appreciated
Con
con244 is offline Find More Posts by con244
Old Jun 19, 2013, 08:37 AM
NYC
Joined Aug 2010
How does it flies binding DSM2 radio? I have dx6i (in repairs right now) and just got OrangeTX T-6 (DSM2) radio. It handles strong gusty winds well?
Torch8 is online now Find More Posts by Torch8
Old Jul 17, 2013, 07:04 AM
Joined Jul 2013
Originally Posted by TurboRacer View Post
If anyone wants my DX8 file I can post it up..
I would like the file please.
dorbo is offline Find More Posts by dorbo
Old Jul 18, 2013, 01:50 PM
Billj747's Avatar
United States, NC, Mooresville
Joined Aug 2012
Just ordered one to compare it to my Mqx LB hybrid.
Anyone have both the V2 and mqx hybrid? How do they compare?
Billj747 is offline Find More Posts by Billj747
Old Jul 26, 2013, 06:11 PM
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
Dead board! only twenty flights on it...
Plugged the bat and nothing no led no throttle response nothing
High hopes not fulfilled, maybe I'll buy a nanoQx board to replace it, maybe not...just
blackmoon is online now Find More Posts by blackmoon
Old Aug 02, 2013, 11:34 PM
Joined Sep 2004
DX7 config for Ladybird DSM2
I didn't find any posts about how to setup the DX7 with the LB DSM2 flight controller.
This is what I did and seems to work fine:
Ladybird DSM2 setup with Spektrum DX7 tx
In SYSTEM SETUP MODE:
Type: HELI (not ACRO)
Swash type: 1 SERVO NORM
Channel reverse: All set to NORMAL, "N"
Set GEAR channel to control GYRO gain, but in this case it's really controlling the flight controller's "Normal" and "3D" modes (0 - 100%).
[INPUT SELECT]
GEAR:
GYRO
This assigns Channel 5/GEAR to GYRO gain control.
In FUNCTION MODE:
Set values for GYRO
Rudder dual-rate switch selects preset values "0:" or "1:"
[GYRO SENS]
RUDD D/R
RATE:
0: 88
1: 10
Then use the "Rudder D/R" switch to toggle between GYRO=88 and GYRO=10, which maps to flight controller's Normal mode (88%) and 3D mode (10%).
Instead of my 88 and 10, use your own values.
fluf is offline Find More Posts by fluf
Old Feb 15, 2014, 06:38 PM
Knife-Edge
servohead117's Avatar
Joined Mar 2013
What are the esc's rated for in this? I want to run the chaoli CL 0820-15 motors with husban props and the motors are rated for a max of 2.75 amps. Is this capable of running those?
servohead117 is online now Find More Posts by servohead117
Old Feb 25, 2014, 06:17 PM
United States, GA, Gainesville
Joined Jun 2004
Will not bind
I just received my board tonight from 9imod and it will not bind. I have a DX9 that I want to use and a DX6i that I have tried and neither will bind.
When the bind plug is in the board I get a blink rate of about one blink per second but it does not bind. With the bind plug not in place the board blinks much faster. I have tried to bind this many times and it seems that either the board is bad or I am doing something wrong but I do not know what else to do. Any help would be greatly appreciated.
Billy
RCACF Billy is offline Find More Posts by RCACF Billy
Old Feb 26, 2014, 02:03 PM
Joined Nov 2004
Futaba 9CHP Ladybird DMS2 Settings
I've spent a couple of hours monkeying around with the Futaba 9CHP transmitter/ Spektrum DM8module to get my Ladybird DMS2 hoverable. I'm not in any way suggesting that these are optimal. For me at least they are good enough to learn how to fly this. I intend to FVP it with a small camera/tx if possible.
Hopefully this may be helpful for anyone who wants to use a Futaba Tx.
Rich
Below are my settings:
Futaba 9CHP LadyBird DMS2 Settings
Parameter:
HELI (SWH1)
PPM
Reverse:
1:AIL REV
2:ELE REV
3:THR REV
4:RUD REV
Exponential: chn 1 30%
chn 2 30%
chn 4 55%
These were the subtrims I used, I would suggest you start with zero on all and see what you get.
1:AIL -22
2:ELE -20
3:THR 0
4:RUD 0
Any attempt at rudder subtrim or rudder stick trim causes my Ladybird to go only through the bind phase "slow blink" but never to a solid light.
richgraf is online now Find More Posts by richgraf
Old Feb 26, 2014, 02:08 PM
Joined Nov 2004
Sorry. Double Post
Old Feb 26, 2014, 10:42 PM
Joined Jun 2004
Wrong board
I got an email back from 9imod and I bought the wrong board. They sent the following message,
"Hello Billy,
What you bought is QR Ladybird V2-Z-02 RX2643H-D which is suitable for walkera model,can not match DX9i."
Oh well. At least I know why it wouldn't bind. If it were heavier I could use it for a paper weight :-)
Billy
For Sale Mcp x V1 & V2 Flybarless 3in1 Control Boards $45 each tunnelvision Aircraft - Electric - Helis (FS/W) 8 Sep 08, 2012 11:23 AM
Discussion Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD Quad_Addict Multirotor Talk 4985 Aug 18, 2012 07:21 AM
Wanted X AIRCRAFT AHRS + Flight Controller - V1 or V2 Jelico Aircraft - Electric - Multirotor (FS/W) 3 Mar 24, 2012 04:44 PM
Found Looking to trade mcpx v2 board + extras for v1 board f.a.r.m.e.r Aircraft - Electric - Helis (FS/W) 1 Mar 14, 2012 10:48 PM
Sold MK Clone FLight control v1.35 gold edition & Dist board Quad_Addict Aircraft - Electric - Multirotor (FS/W) 11 May 26, 2011 09:00 PM
