Old Jul 28, 2011, 04:45 AM
Multi Rotors Rule ! ;-)
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
R/C HELI Ground clearance - Landing gear - Underslung camera ?
Hi guys,
I've effectively built my (AP) Tricopter, however have a final challenge!...
The camera will be mounted under the frame, however this then requires more ground clearance, so the camera mount + camera aren't fouling the ground, before and after takeoff - while the Copter is on the ground !
So what landing gear ideas are you using to provide this additional ground clearance ?
I did buy landing gear designed for a large class R/C Heli, thinking this would be quite a big item, with space underneath once fitted for camera etc, however thats not the case - it still wont be "tall" enough!
SkyEyes is offline Find More Posts by SkyEyes
Old Jul 28, 2011, 07:44 PM
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Originally Posted by SkyEyes View Post
Hi guys,
Never used landing gear..... I just hand launch and catch....
signguy is offline Find More Posts by signguy
Old Jul 29, 2011, 10:00 AM
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
Hi Signguy, thankyou for your reply. Yeah, good point, if its a plane
However it is actually a Tricopter, therefore a little more tricky to hand launch and catch?
Nice to have the Copter setup and primed on the ground, then stand back and take her up. Especially when you have to play around with camera equipment on the craft each time, prior to the "flight" (or hover).
As the Tri frame is made out of " [ " shaped rods, I'm planning to cut and shape a few metal strips, that'll just be bolted to the frame and shaped underneath, to form Skids.
Old Jul 29, 2011, 10:02 AM
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
.... LOL - Or perhaps I could hand launch the Tricopter into the air, using the same approach as a Boomerang !!
Big toss, and up she goes - now I just need to stop her spinning, bit of opposite cyclic, and bring her into a stable hover! Ahhh, easy.
Would certainly make on-board video fun to watch, if a little giddy!
Old Jul 29, 2011, 07:12 PM
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
Long pool noodle legs
works for me and I have a short set of legs for when I just fly
my 2 cents
Rob
onlyifamppowered is offline Find More Posts by onlyifamppowered
Old Jul 30, 2011, 10:48 PM
Gress Aero
GaryGress_1's Avatar
Joined Jul 2009
Hi SkyEyes,
I use use these on my bicopters when slinging cameras underneath:
http://www.hobbyking.com/hobbyking/s...dproduct=10019
and sometimes even these:
http://www.hobbyking.com/hobbyking/s...dproduct=10022
You'll have to cut the feet or grippers off your heli gear and then attach them to these struts - if you want skids.
All told, a relatively expensive solution compared to ~$12 for standard heli gear.
Gary
GaryGress_1 is offline Find More Posts by GaryGress_1
Old Jul 31, 2011, 08:20 PM
signguy's Avatar
Joined Dec 2004
I hand launch and catch all my multicopter, tri's and quads. I wouldn't try it with a heli, but the multi's are pretty easy to catch. Just set them up close, at waist level. Apply just enough power to make it climb very slowly, walk under it and grab the center under the copter ( away from props ) Thats it, easy
Old Aug 02, 2011, 01:41 AM
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Stick legs is my preferred option
The hexacopter is still being built, but I literally finished building the undercarriage legs yesterday so I can post a better photo soon
Cheers!
David
Hogster is offline Find More Posts by Hogster
Discussion Landing Gear/ Stablized Camera Mount for Sale Tarro Multirotor Talk 3 Jul 24, 2011 07:49 AM
Discussion To landing gear, or not to landing gear..that is the question. kieran142 Beginner Training Area (Aircraft-Electric) 8 May 09, 2011 07:59 AM
Discussion Landing gear ground angle pro547 Mini Helis 1 Jul 28, 2006 03:19 AM
Question Landing Gear Geometry and Ground Loops Dave Moore Sport Planes 26 Sep 02, 2004 06:23 PM
