Old Oct 11, 2012, 11:26 PM
United States, TN
Joined Mar 2011
Is It Possible To Waterproof Analog Servos?
Is it possible to waterproof some or all analog servos, if so how do you go about doing it?
I know that Traxxas makes waterproof servos but they are expensive.
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Oct 14, 2012, 07:23 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thank you!
Most have pretty well sealed seams, but a smear of Goop wouldn't hurt. Then pay particular attention to where the cable emerges from the case -- again Goop does a good job. Finally, put Vaseline around the output shaft.
Note that it's not enough to waterproof the circuit board with CorrosionX or similar as the feedback pot is vulnerable to water (as I found out the hard way). So you must keep the water out of the servo case.
Analog are no different from digital for purposes of waterproofing, other things being equal.
Finally, pay attention to the way the servos are installed. Try to avoid putting them down in the bottom of the fuselage or other places where water may collect and remain for long periods.
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Free Used Tower Pro SG90 9g Analog Servo Dave8888 Free Items 2 May 06, 2012 10:22 PM
Discussion difference between digital and analog servos phil alvirez Radios 4 May 01, 2012 07:00 PM
Wanted Volz analog servos dang Aircraft - General - Radio Equipment (FS/W) 3 Apr 17, 2012 12:27 PM
Discussion Servos: analog-digital zeezee Electric Plane Talk 2 Feb 23, 2012 02:33 PM
