Old Sep 13, 2004, 12:16 AM
Maniacal Super-Villian
Hank Scorpio's Avatar
Toronto Downtown, Canada
Joined Jun 2004
Anybody know about this covering?
This Bomber is covered in an Aluminum finish called "Skinni Dip" and it only added 8 ounces to an aircraft this size!
http://www.rcwarbirds.com/feature.html
Apparently it's an aluminum paste that's applied after the model is sprayed with an adhesive. The excess is wiped off and you're left with an ultra thin aluminum skin that's clearcoated I'd imagine. That's all I've heard but does anybody here know about this stuff. Is it any good? The only place I can find it available is here:
http://www.impscale.com/parts.htm
Looks amazing on that bomber.
Edited 1st URL
Hank Scorpio is offline Find More Posts by Hank Scorpio
Old Sep 13, 2004, 04:05 PM
Joined Jun 2004
Really? Nobody's ever even HEARD of this stuff?
Old Sep 13, 2004, 04:33 PM
Derek_TX's Avatar
Joined Dec 2002
Try a scale channel to post that query. This may be too general.
Derek_TX is offline Find More Posts by Derek_TX
Old Sep 13, 2004, 05:30 PM
R. Carver's Avatar
Oviedo,FL
Joined Dec 2000
Hank,
Try one of the hobby shops over in the hobby district...
Sorry, couldn't resist.
R. Carver is offline Find More Posts by R. Carver
Old Sep 13, 2004, 07:31 PM
Joined Jun 2004
Boourns, Booourns! Man I really gotta change my handle. If I hear one more joke about the Hammock District or the Denver Broncos....
Old Sep 13, 2004, 11:18 PM
Proud to be a Belgian.
rafgol's Avatar
Averbode, Belgium.
Joined Jul 2004
Metalized Polyester Tape Application for R/C Aircraft.
By Carl Bachhuber
Some of you have asked how I simulate the aluminum finish on some of my scale aircraft. Since the 1980's I've been experimenting with types of Metalized Polyester(MP) tape. 3M and others manufacture it mostly for silk screening, and slide masking. It also can be used as I've found on model aircraft.
Well let me give you some of the advantages. Unlike heat shrink coverings this will not bubble or loosen over time. I've had it on one airplane for over 12 years and it really looks as good as the day I put it on. It is much stronger than plastic films. It is easily repaired. Applying the tape is a fairly fast process and it can also be painted. The tape is impervious to Gasoline, Methyl Ethyl Ketone(MEK) and most other thinners. It is lighter in weight than most paints. It is about 2 mils thick and is non-conductive. Mixing and matching different types of materials such as aluminum tape, paint and MP tape can create a very realistic finish.
Disadvantages. Well, the biggest disadvantage is the limited ability of the tape to conform to compound curves. A bit of heat helps but if the curves are too sharp you may need to cut the tape or come up with a different method of metal covering simulation to achieve a satisfactory result. MP tape is for covering solid surfaces not open bays.
Prepare the model the same way you would for paint. I usually cover the model with a 3/4 oz. glass cloth and a laminating epoxy although polyester resin can be used also. I use an acrylic auto primer after the model has been sanded. Instead of spraying on the primer try using a short nap small paint roller. Seems to be a very fast process with no overspray. Sand and fill till your satisfied. Remember, too much sanding is never enough. Once satisfied, wash and wipe down the model so that it is as close to clean as possible. You should now be ready to apply the tape. I use a squared sheet of metal as a cutting board. Since the tape has an aggressive adhesive on one side put that side to the cutting board and unroll a length. Cut into the desired panels. Buff with Scotch-brite if you want that abused aluminum look instead of a mirror finish. Make sure you have removed all particles from that process and the aircraft lest you should have contamination under the tape after it is applied. Now, raise an edge of the panel with a Xacto knife and peal it off the cutting board. Place the panel on the desired spot on the model and press from the middle of the panel to the outside to keep air entrapment to a minimum. You might also want to keep a covering iron on a high setting while your working as it can be helpful on minor compound curves. Again work from the inside out. Don't worry if you screw up a panel just peel it off and reset or toss it out.
After your finished applying the panels you might want to try simulating rivets by using r/c 56 glue for raised rivets. In the case of flush rivets the hot tip of a wood burning tool shaped like a rivet works very well although it takes too much time for me. Instead I came up with a "dritz wheel" like tool with brass tubing spokes which does an acceptable job of making rivets fast.
If you want to experiment with this material it can be found in manufacturers directories under specialty tapes. Look for 3M #850 or equivalent. One company Specialty Tapes uses the part number #298 Silver metallic tape in their catalog. Don't be afraid to shop around. There are others. Good luck!
rafgol is offline Find More Posts by rafgol
Old Sep 14, 2004, 12:53 AM
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
I have heard of it but never used it. It used to be written about in "Scale RC Modeler" now defunct. The guy who sold it was related to the publisher I believe. It was then only available form one place then.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Discussion Does anybody know about this plane? Cessna 182 Parkflyers 3 Dec 09, 2006 05:03 PM
Help! Anybody know about this motor? Cessna 182 Power Systems 0 Feb 23, 2006 06:08 PM
does anybody know about this cub Pablito Parkflyers 2 Feb 09, 2002 10:03 PM
How many people know about this little Juno trick to block the ads? electricman45 Life, The Universe, and Politics 3 Sep 11, 2001 11:19 PM
