Old May 29, 2014, 01:15 AM
RS2K's Avatar
United States, KS, Wichita
Joined Apr 2007
Why does the CO alarm in my garage go off when I charge my vented NiCd batteries?
I use a pair of 28V 46 AH Nicd batteries for field charging. I usually fast charge them at home at .5C the night before I head out to the field. My CO detector is placed right above where I charge my batteries. Just before my charger detects a battery is fully charged (3mv delta V peak detection) my CO detector will go off and show somewhere around 300 PPM.
I don't think CO can possibly be generated by charging a Nicd, but I know charging a nicd does produce hydrogen and oxygen. I'm guessing the the hydrogen is what's causing the alarm to go off. If this is the case, can a NiCd produce enough hydrogen to cause a fire?
RS2K is offline Find More Posts by RS2K
Old May 29, 2014, 08:55 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Perhaps it's electronic interference from the charger that is triggering the CO monitor. I believe chargers use square wave forms that can generate a lot of spurious signals that may adversely affect other electronic devices. Try moving your charger a few feet away from the monitor and see if it is still triggered.
whitecrest is offline Find More Posts by whitecrest
Old May 29, 2014, 09:06 AM
Joensuu, Finland
Joined Mar 2002
I don't believe NiCd produce any gas at all. Think about it: if hydrogen was released at every recharge and nothing was added into the battery, it would run out of chemicals quite quickly.
Wet lead-acid batteries do produce H2 and O2 through electrolysis and need to be periodically topped up with distilled water.
jkettu is online now Find More Posts by jkettu
Old May 29, 2014, 10:19 AM
RS2K's Avatar
Joined Apr 2007
I'll try moving the CO monitor and see what happens.
I do have to top off the electrolyte at least every 6 months with distilled water. I checked the electrolyte level just a few days ago, The battery looks like this:
The center cap on each cell comes off and the electrolyte, a mixture of potassium hydroxide (AKA lye / potash / caustic soda) and water, needs to be 22 mm from the top.
Old May 29, 2014, 10:56 AM
United States, MN
Joined Feb 2011
If it's gassing it is likely giving off hydrogen. A quick search of Google turns up several reports that hydrogen gas can interfere with carbon monoxide sensors. Most people report it when charging lead acid but in this case you're dealing with the same gas.
grimbeaver is offline Find More Posts by grimbeaver
Old May 29, 2014, 10:58 AM
WJH
United States, FL, Spring Hill
Joined Aug 2005
Are you sure your field batteries are nicad?
WJH is offline Find More Posts by WJH
Old May 29, 2014, 11:11 AM
United States, MN
Joined Feb 2011
That's what he has. I didn't realize such a thing as vented nicd existed but it does:
http://en.wikipedia.org/wiki/Nickel%...cell_batteries
Old May 29, 2014, 12:06 PM
RS2K's Avatar
Joined Apr 2007
I was finding information about hydrogen suflide being able to set off a CO alarm, but nothing about pure hydrogen. I found that it takes 40,000 PPM for hydrogen to be flammable. I don't think it's possible for these batteries to produce hydrogen at a high enough rate to pose a problem.
These are condemned private aircraft batteries. Per manufacturer specs they need to hold at least 100% of the rated capacity at 1C for 1 hour to be flyable. They were condemned because they could only hold a 95% charge. They work great for field charging. I can get just over 80 AH out of both of them at over 24 volts.
Old May 29, 2014, 01:21 PM
United States, MN
Joined Feb 2011
Well it's supposed to take 400 ppm to set off a CO detector. This page indicates that (for their CO measurement tool) hydrogen will generate a false positive at a rate of 10-15%. So assuming your CO detector is similar anywhere between 2666 ppm and 4000 ppm of hydrogen will set off a carbon monoxide detector. Which as you found is far from the flammable point.
Old May 29, 2014, 01:38 PM
RS2K's Avatar
Joined Apr 2007
Thanks! That's great information. My CO meter has a readout. It goes off when the level is 100 ppm for XX amount of minutes. The higher the PPM level the less time it takes for the meter to send an alarm. My CO alarm goes off just before the charger switches to trickle charge.
Old May 29, 2014, 05:29 PM
Florida
Joined Aug 2004
We used a lot of those wet cell NiCad's on aircraft instrumentation back in the late '50's. Very good for high current use but rather bulky and could get messy at times but far superior to the other choice which was a Pb cell.
Rodney is online now Find More Posts by Rodney
Help! Why does my gimbal ROLL move when my Tri does YAW movements? SwissBoy Multirotor Electronics 9 Nov 12, 2014 05:43 AM
Question Why are my lipos draining when my plane is switched off RcjunkieAZ Batteries and Chargers 7 Jan 07, 2014 06:58 AM
Discussion Why Does My Blade Cx3 Md520 Tip To Left When Trying To Take Off. BEAR X Electric Heli Talk 9 Jul 18, 2009 02:44 PM
Discussion When to charge my NiCD batteries for longer life? OrlandoP Batteries and Chargers 8 Jul 26, 2007 08:08 AM
Discussion Why does my Swallow charger show more Votage then my Graupner when fully charged ??? sebbe Batteries and Chargers 3 Jun 13, 2007 06:06 AM
