Old May 06, 2013, 10:55 AM
Whiplash46's Avatar
Maryland
Joined Jul 2007
Wing Building
Once all the parts were cut it took a few hours to fit the ribs onto the main spar. Once that was done and the joiner tubes were made and fit, the root to fuselage joint has a 1" alum. tube on the front side and 3/4" on the rear, it only takes about 5 minutes to assemble the wing to the level of completion shown. Using the box spar and interlocking crutch the whole thing can be fit together without glue. The only thing left to add is the 1/64" ply L.E. sheet and pre formed Poplar L.E. along with the simple rectangular aft spar caps. The T.E. is just a 1" wide strip Top/Bottom of 1/32" ply. Since I was duplicating all of these same steps for the right side as I was making the left, that panel should only take a short time to assemble. I hope to be covering this weekend.
Whiplash46 is offline Find More Posts by Whiplash46
Old May 06, 2013, 09:13 PM
USA, MD, 8
Joined May 2010
Wow! That thing is HUGE!!
SStricker is offline Find More Posts by SStricker
Old May 06, 2013, 09:46 PM
Vintage wood is the best!
SZD16's Avatar
In a house
Joined Sep 2002
What are the two white tubes for?
SZD16 is offline Find More Posts by SZD16
Old May 07, 2013, 08:59 AM
Whiplash46's Avatar
Maryland
Joined Jul 2007
White Tubes?
The tubes are guides for the aluminum stub spars. These serve 2 purposes, 1) give me a little peace-of-mind that the main spar is strong enough at the root and 2) just make it easier to attach the inner wing panels to the fuselage. The tubes are made from 4 layers of 24# craft paper saturated with a 2 part Poly-Urethane plastic (http://www.polytek.com/). The outer 2 white tubes serve the same purpose at Rib15 where the outer panel joins the inner. In the images I posted the tubes have not been trimmed flush to the ribs yet. Looking at the structure as built, the box spar is probably more than strong enough to do the job.
Old Jun 20, 2013, 09:49 PM
bendix1's Avatar
United States, CA, San Jose
Joined Jan 2013
that's a nice build
bendix1 is offline Find More Posts by bendix1
Old Aug 17, 2013, 12:15 AM
SZD16's Avatar
In a house
Joined Sep 2002
Whiplash....have you made anymore progress?
Old Aug 19, 2013, 02:35 PM
Whiplash46's Avatar
Maryland
Joined Jul 2007
Progress
Its been slow, I lost steam when I new I wasn't going to finish in time for the JR
Aerotow. Have been making some progress though, will try to make it to Cumberland, MD in the Fall. It's bigger than my shop can really handle so in order to assemble it I have to take it outside. Building toy airplanes is a lot of work!
Old Aug 19, 2013, 03:14 PM
csc
United States, AZ, Phoenix
Joined Apr 2004
Nice!
csc is offline Find More Posts by csc
Old Aug 19, 2013, 03:18 PM
United States, VA, Herndon
Joined May 2007
Looking awesome!
wilmracer is online now Find More Posts by wilmracer
Old Aug 19, 2013, 04:07 PM
United States, AZ, Sierra Vista
Joined Jun 2006
Nice build Whiplash, I see Sstricker also replied.
mgutman is offline Find More Posts by mgutman
Old Aug 19, 2013, 05:14 PM
Whiplash46's Avatar
Maryland
Joined Jul 2007
High praise from you MGutman. Thanks, yes SStricker keeps me motivated. Hope all is well.
Old Aug 19, 2013, 09:43 PM
SZD16's Avatar
In a house
Joined Sep 2002
Looking good!
And yes...it is work!
I have plenty of projects in "progress" to testify to that!! 8-)
Looking forward to seeing it at Cumberland! Even if you don't finish it you should bring it up just to show it off!
Old Aug 19, 2013, 11:33 PM
United States, KY, Taylorsville
Joined Mar 2010
Looks great!
ARUP is online now Find More Posts by ARUP
Discussion Scratch Build RQ-7 Shadow Composite/Balsa parri0923 Balsa Builders 2 Jan 17, 2013 05:17 PM
Build Log Binder EB29 1/4 scale 7.3 meter scratch build yyz Scale Sailplanes 564 Dec 13, 2010 10:09 AM
For Sale Nomad R/C Car - 7.2V Electric copterklutz Cars - Cars and Parts (FS/W) 4 Aug 22, 2006 03:14 PM
