Old Nov 15, 2014, 04:23 PM
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Originally Posted by borntoolate View Post
Yep! Alcohol, windex or water all work to thin the HD latex paint. I prefer water myself.
Bob
How much water do you typically add to the paint?
Kman
kman24 is offline Find More Posts by kman24
Old Nov 15, 2014, 04:57 PM
modify...modify...modify
borntoolate's Avatar
United States, CA, Sunnyvale
Joined Mar 2012
Kman
I usually add between 25-40%. It just depends on how thick the paint is when I mix. Some of my paints have been with me for a few months to a year. They tend to get a bit thicker. No problem, they just get a tad more water. Mix and shake well then airbrush.
The paint I am using to paint my B-17 is relatively new, so it only took about 25% water to get the consistency I needed for the airbrush.
Bob
borntoolate is offline Find More Posts by borntoolate
Latest blog entry: B-17 maiden flight Nov.23, 2104
Old Nov 15, 2014, 04:58 PM
USA, NY, Poughkeepsie
Joined Mar 2010
There's a lot of variables as to thinning( air pressure,needle/mix cap size, viscosity of paint ). I've read in some other kit bashers threads that with Home Depot samples they thin by as much as 65% with either windex or Isopropyl. I'd suggest starting at 50% and try it out on paper plates( the dollar store kind) If your air pressure is not adjustable play with the thinning until you get the consistency you can control the flow with out running the paint.
I wouldn't use plain water to thin, stick with either windex or alcohol.( both work better than water at keeping the flow smooth and help the paint to dry faster).
If you're using craft store acrylics, they will probably need less thinning.
rcguy1958 is online now Find More Posts by rcguy1958
Old Nov 15, 2014, 06:39 PM
kman24's Avatar
Joined Jan 2010
Thanks for the tips guys. My B'day is coming up and I hope to be getting the Dynam BF-110. That plane will be my next big repaint this winter. First time with an airbrush
Kman
Old Nov 15, 2014, 10:52 PM
United States, CA, San Diego
Joined Feb 2014
So just regular acrylic paint? Safe for foam? No need to use expensive enamel paints from hobby shops?
I tried some paint from spray can at Ace hardware and it makes foam swell up, "dinosaur skin"! !
Great tips for thinning
Thx
Sabyx5 is offline Find More Posts by Sabyx5
Old Nov 15, 2014, 10:59 PM
Joined Mar 2012
Thx
The paint I buy from Home Depot is regular flat latex house paint. It is water soluble and is a very easy clean up. I don't use the enamels or the spray paint in cans. Others do, but I have found that Home Depot will computer color match nearly every color I need r want. It cost $2.93 fr a 7.5 ounce sample. That is enough to paint a plane numerous times with paint left over. "Hobby store" paint at nearly $4-$5 for a 1/2 to 1 ounce ounce bottle just makes no economic sense to me.
Old Nov 15, 2014, 11:14 PM
kman24's Avatar
Joined Jan 2010
Krylon Fusion spray paints work good on Dynam foam. No problems with it getting sprayed directly onto the foam.
Kman
Old Nov 16, 2014, 04:30 AM
United States, NJ
Joined Apr 2012
yup im liking latex so far
bullworm is offline Find More Posts by bullworm
Old Nov 16, 2014, 06:35 AM
Joined Mar 2010
If you're not looking for specific color matching, the small bottles of craft paint sold at Michaels, Hobby Lobby, Walmart can be used to air brush on any foam as they are fully water based.
http://www.michaels.com/painting/craft-paint/809188094
Apple Barrel and Craftsmart brands flow very nice when thinned with Isopropyl and at 79 cents a 2 oz. bottle they're very affordable, 4.99 for 16 oz. bottles.
Liquitex makes the best water based spray cans in some amazing colors
http://www.michaels.com/liquitex-pro...Black#start=48
The Michaels near me carries Createx and Wicked Paints designed for airbrushing and they require less thinning.
Old Nov 16, 2014, 07:05 AM
Joined Mar 2010
One last thing, stay away from the Folk Art brand for airbrushing. Very difficult to get consistent flow and they tend to clog the airbrush ( my experience anyway).
Guess it's more than one last thing , The Liquitex spray cans are expensive, but the amount and quality of the paint is outstanding and there are a number of different aircaps available for different effects. The caps can pretty much turn a spray can into and airbrush.
Old Nov 16, 2014, 12:38 PM
Joined Feb 2014
Thx all!!
Old Nov 20, 2014, 06:18 PM
Joined Mar 2010
Got the fuse sealed in flat acrylic, started applying the Callie Graphics
Old Nov 20, 2014, 06:41 PM
Santa Cruz, CA
karltrek's Avatar
United States, CA, Santa Cruz
Joined Sep 2011
Looks great. Nice!
karltrek is offline Find More Posts by karltrek
New Product FW-190 Typ B 1200mm EPO retracts lights mopetista Electric Warbirds 18 May 24, 2012 12:15 PM
Sold Hobbico Flyzone Focke-Wolf 190 RxR FW-190 propflipper Aircraft - Electric - Airplanes (FS/W) 10 May 08, 2012 07:07 AM
Build Log GWS FW-190 in EPO Foam mcsarge Electric Warbirds 259 Feb 20, 2010 05:58 PM
Discussion Just finished my EPO FW-190 TopSpin GWS (Grand Wing Servo) 34 May 22, 2009 06:55 AM
Sold GWS EPO FW-190 PNP Brushless + Retracts!! $150 SHIPPED!! Andrew1944 Aircraft - Electric - Airplanes (FS/W) 2 Jul 21, 2008 03:26 AM
