Old Nov 08, 2014, 05:13 PM
RCG Hover Pincess'
Eagle2Nitro's Avatar
United States, LA, St Francisville
Joined Apr 2014
Originally Posted by turboparker View Post
Hi King,
For the UMX planes, you want the second one with the PH-3 connector. Be sure to check the CG on your plane. She flies much, much better when balanced at the sweet-spot than she does when flown nose-heavy. To get the CG back to the sweet-spot on mine, I mount the TP 325 pack sideways in the compartment, nearly all the way aft. About where the Hyp 330 is mounted in the pic below.
Joel
Isn't the batt in the pic a Hyp 320?
Eagle2Nitro is online now Find More Posts by Eagle2Nitro
Latest blog entry: RCG Hover King Title
Old Nov 08, 2014, 05:34 PM
You smoke, you litter!
Joined May 2008
Thank you kindly Joel. Did you find a seller with a price better than 16.99$ per pack?
King of Plane is online now Find More Posts by King of Plane
Old Nov 08, 2014, 05:57 PM
Gopher huntin' stick jockey
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
E2N,
Yup. Fixed. Good catch!
King,
I haven't found anyone selling them for less than that. But they last for up to 600 cycles at a whopping 12c charge before they start to fade away. At 12c charge, it only takes around 7 minutes for a full charge from the 80% discharge point. I can charge at the field & fly non-stop all day long with only 2-3 packs - instead of buying a fistful of cheap packs that don't provide anywhere near the same power-to-weight, can't handle fast-charging without a reduction in performance and/or cycle-life, and typically start to fade away after just 20-50 cycles or so - even when pampered.
I don't worry about the higher initial cost of the TP packs because they're actually a much better bargain over the long run than any of the other UMX packs I've tried.
Joel
turboparker is online now Find More Posts by turboparker
Help! Adrienne Paige Gee Bee R2 Plans Eric Giorgiantonio Fuel Plane Talk 5 Jan 30, 2012 12:02 AM
For Sale Herr Gee Bee R2 (NIB) 25" wingspan pdawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Oct 12, 2011 11:20 AM
Wanted Adrian Page Gee Bee Z 1/5th and/or Gee Bee R2 1/5th (looking for) Xanix Aircraft - Fuel - Airplanes (FS/W) 0 Jul 23, 2007 07:16 PM
