Old Jun 18, 2010, 01:41 AM
chuck
santa barbara, CA
Joined May 2009
5400 or 4800 p3 f16
don, going to get a motor for dads day, im looking at the 5400 or 4800 for a p3 f-16. can you tell me where to look for speeds i can expect on 4 cells for both motors with the stock fan, which is a xf correct?
also im a little confused as to the needed plug as the text seems to say none are needed, but the options show a plug for xf/ eflight, did i miss something here?
thanks for the info and cool sale!
chuck.
chas650r is online now Find More Posts by chas650r
Old Jun 18, 2010, 07:39 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
If you are going stock fan go the 5400 then you can fly 3S or 4S. 3S will be like "stock" power and 4S will be more. If you still have the factory rotor adapter then you can use it, I give people the option to buy a XF/Eflite adapter as some have bad factory adapters or loose them.
The Don is offline Find More Posts by The Don
Old Jun 18, 2010, 11:18 AM
chuck
santa barbara, CA
Joined May 2009
don,thanks for the quick reply.
chuck.
Old Jun 18, 2010, 01:54 PM
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I've got a Don's 5400 on the stock fan in my P3 F16 and it's a screamer on 4S.
Dave
davecee is offline Find More Posts by davecee
Old Jun 18, 2010, 04:04 PM
United States, OH, Cincinnati
Joined Mar 2008
ESCs
What ESC would you need for the5400 and/or 4800?
Oryon is online now Find More Posts by Oryon
Old Jun 18, 2010, 04:37 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The 40 will be OK.
Don
Old Jun 18, 2010, 07:03 PM
chuck
santa barbara, CA
Joined May 2009
Dave
thanks dave ,
sounds like the 5400 is the one!
if you dont mind , what battery are you using and how fast do you think it is?
Old Jun 18, 2010, 07:33 PM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I'm using a 4S 2200 mah 25C Tenergy pack. I don't have an accurate idea of it's speed, but in comparison to a few jets at the field, it's faster than a 5S Habu (stock fan/motor) and a good bit faster than a HL F-86 with a Don's 4800 on 3S. It's perhaps a bit slower than an Alpha A-4 with a Don's 4800 on 4S and about on a par with a 4S AMX A-1.
Dave
Old Jun 18, 2010, 07:34 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
A 4S2200 is a commonly used pack. I have dopplered them at 95-100 mph, depends if you reduce the outlet nozzle diameter down.
Don
Old Jun 20, 2010, 02:01 AM
chuck
santa barbara, CA
Joined May 2009
don and dave , thanks for the additional info. 100 mph would be great . should just the 4 cell taileron upgrade be the only needed mod as i sure like to keep em light.
happy dads day to all,
chuck.
Old Jun 21, 2010, 10:35 AM
chuck
santa barbara, CA
Joined May 2009
2 motors ordered, thanks don
chuck
Old Jun 21, 2010, 01:55 PM
Joined Mar 2008
Getting ready to order the 5400 for a 4s on a 40amp ESC... this will be good, yes? (with stock fan)
Also, aside from CF bracing on the taileron attach points, is there anything else i need to do to this bird to make her hold up to the speed I will get out of that setup?
Also, where in the fuse is the best point to place the fan unit, for CG, so I caan fly both 3s2200 and 4s2200?
Thanks!
Matt
Sold Don's Wicked 5400/50mm Wemo Combo FS or Trade Lardog Aircraft - Electric - Power Systems (FS/W) 3 May 19, 2010 12:43 PM
Question lander fan in blitz f16 or pure lander f16 ucanibo Foamy EDFs 3 Dec 28, 2009 08:39 PM
Question 3S with 5400 & Alfa 3 blade OR 4800 & Alfa 5 blade? rongreg13 Don's RC 6 Nov 17, 2008 02:25 AM
Wanted looking for gws a10 or stock setup from p3 f16 riechsoldier1 Aircraft - Electric - Jets (FS/W) 4 Sep 11, 2008 11:32 AM
Wanted WTB Himax 2015-5400 or E-Flite 370-5400 flanker Aircraft - Electric - Power Systems (FS/W) 5 Aug 23, 2006 06:46 PM
