Old May 03, 2001, 03:40 PM
NewbieX is offline
Find More Posts by NewbieX
Human Like You
NewbieX's Avatar
Colorado
Joined Feb 2001
Zagi Thrust Line and cg?
I've managed to wack up the canopy and tray and decided to remove them. I have built a little motor mount out of some packing foam. Should the motor shaft be flat to the wing and straight through the middle or does it have a little adjustment in either direction?
The wing is clipped by 4". Should I have the cg at 8" same as stock or move it forward at all?
Thanks in advance for any help.
NewbieX is offline Find More Posts by NewbieX
Old May 04, 2001, 01:04 AM
Kevin Graehl is offline
Find More Posts by Kevin Graehl
Kevin Graehl's Avatar
myspace.com/graehl
Joined Mar 2001
thrust line is not that big of deal on a ZAGI
just lay the plane right side up on a table then mount your motor parrelel to the table
dont know if that made any sense
let me try to explain it this way
put it on the table the use a level to adjust the angle so it is flat with the earth
make sure the table is flat too
just use your eyes
if at full throtle in the air and the plane falls or rises adjust the motor accordingly
as for the cg
8 inches is conservitive on a regular ZAGI 400 try 7.75 to 7.35 inches
i like to fly mine to the point where if i move back my RS 1600 pack just an .125 of an inch it won't turn without spining out of a turn
hope that helped
Kevin Graehl is offline Find More Posts by Kevin Graehl
Thrust Line, ZLL, CG, tail moment HELModels Modeling Science 33 Oct 04, 2004 05:31 AM
Zagi thrust line? Randahl R Foamies (Kits) 1 Aug 15, 2003 10:30 PM
Zagi 400X- Thrust line importance? pmanaz Foamies (Kits) 0 Apr 17, 2002 05:02 PM
A Zagi thrust line question mtayl Foamies (Kits) 5 Jan 01, 2002 10:33 AM
Zagi thrust line? NewbieX Foamies (Kits) 0 May 01, 2001 05:35 PM
