Old Mar 07, 2015, 06:48 AM
Jaketheone46 is offline
Find More Posts by Jaketheone46
Jaketheone46
United States, KY, Florence
Joined Nov 2014
Power supply knowledge.
I have a power supply question. I see supplys that say switching and others that don't say switching. Is this the switching like on a BEC like where if it's not a switching psu it's a linear psu??? And if so can you explain please. I understand why the switching effect would be needed in a BEC cause your stepping down voltage but with a power supply your pretty much making more power ??? I have not thought into this much and really hate asking as I like being the guy that has the knowledge. As for power supply's I've never had one besides a unit pulled out of a pc I have now it's a elements z power standard series 300 watt model ap-350x the main 12 volt rail says 12 volts at 15amps 180 watts. Is this a decent supply to convert. If it converts to being able to produce 12 volts at 12 amps reliably I would be totally happy. Can any one answer any of my questions please???
Jaketheone46 is offline Find More Posts by Jaketheone46
Jaketheone46
Joined Nov 2014
Ps this is my first ever thread.
Old Mar 07, 2015, 07:12 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Here's a good explanation of the differences between linear and switching power supplies:
http://www.mastechpowersupplies.com/...er-supply.html
Ohmic is offline Find More Posts by Ohmic
Old Mar 07, 2015, 07:17 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I believe the difference between "switching" and other is the means of achieving the output voltage. Traditionally power supplies used heavy transformers to convert the input AC voltage to the approximate output voltage. The switching power supplies use solid state (transistors, etc) and are much smaller and lighter.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Mar 07, 2015, 08:00 AM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
no way you can make more power than you're putting into the PS unless you achieve greater than 100% efficiency.....
anyways liner just uses a transformer to either step up or step down the AC voltage at it's standard 50-60Hz.
a switching PS will convert that 50-60Hz to something way, way higher so that it can use a much, much smaller transformer to step the voltage up or down. if using a DC input then that is also converted to a high frequency AC before being transformed.
you can usually tell linear from switching by the weight of the unit compared to the power capability. they won't always say "switching" or "linear" on the label.
ZAGNUT is offline Find More Posts by ZAGNUT
Old Mar 07, 2015, 08:18 AM
Jaketheone46
Joined Nov 2014
I have a chance to get hobbykings 540 supply for a decent price. It's been tested and works well. Is this a decent supply. Is it a switching unit.
Old Mar 07, 2015, 10:59 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
It should work just fine at producing 12V at 12A after conversion.
http://web2.murraystate.edu/andy.bat...owersupply.htm
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
http://www.instructables.com/id/Conv...gular-DC-Powe/
It's probably an acceptable quality power supply. Certainly not in the same league as a server supply but should work just fine.
And yes, like nearly all power supplies that are designated for hobby use, it is indeed a switching supply.
mrforsyth is offline Find More Posts by mrforsyth
Old Apr 06, 2015, 07:08 AM
Jaketheone46
Joined Nov 2014
Thanks very much.
Discussion Cheap and powerful 12v power supply - EVGA 430 - 600 series APX power supplies. Paul Penney Batteries and Chargers 0 Jan 02, 2015 05:38 PM
Sold Thunder Power 610 charger and Power Supply. hosam Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 05, 2014 11:14 AM
For Sale GT Power A620 400W-20A 6S LiPO Charger w/ 650w power supply chevyfried Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 03, 2014 10:13 AM
Help! HELP with first PC power supply to lab bench power supply Ebolavoodoo DIY Electronics 2 Oct 21, 2014 08:14 PM
For Sale Desktop Power Supply / Lab Power Supply MadMedInc Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 01, 2014 03:03 PM
