Old Today, 01:09 AM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
Orange County, CA
Joined Aug 2004
I sent an email to the folks in Champaign. I'll let you know what they say.
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Today, 01:49 AM
DaxFX is offline
Find More Posts by DaxFX
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
I just finish redo the ext-v wiring and solder. conected and make a new model in tx and same thing happened, i swap for another rx and was reading 0.01v more than my lipo tester so that was a perfect reading i did conect back the first rx and the reading went bad again.
DaxFX is offline Find More Posts by DaxFX
Old Today, 01:50 AM
DaxFX is offline
DaxFX's Avatar
Joined May 2008
Thank you, :-)
Old Today, 01:58 AM
DaxFX is offline
DaxFX's Avatar
Joined May 2008
Originally Posted by Finnspeed View Post
Can you measure if the pico fuse is OK? You need a multimeter for that. Also is your RX voltage correct? I see 4.7 V in the picture. If it should be 5 V or above, then the problem is affecting all voltage measurements. The next step would be replacing the RX to see if it is the culprit in that case.
Good catch, im powering thr rx from a NAZA i always use the mini osd for telemetry but i just decide to take out fpv and use this one for LOS flight, what voltage should i be reading from the naza?
Old Today, 04:57 AM
Finnspeed is online now
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
I don't know what the Naza internal regulator puts out but I would guess 5.0 - 5.2 V. That's why I thought that 4.7 V is wrong and I suggested to try another RX. Turns out, it was the RX after all which was faulty.
I hope you can get the faulty one replaced or serviced under warranty.
Finnspeed is online now Find More Posts by Finnspeed
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 06:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 04:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 10:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 09:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 08:45 PM
