Old Nov 19, 2009, 12:24 PM
Ryan Archer is offline
Find More Posts by Ryan Archer
United States, AZ
Joined Aug 2004
lightweight foam primer?
does a lightweight primer, that will not eat depron, exist? i'm having a heck of a time finding one that works worth a dang.
ryan
Ryan Archer is offline Find More Posts by Ryan Archer
Old Nov 19, 2009, 12:33 PM
Rich` is offline
Find More Posts by Rich`
It Flies !!!
Rich`'s Avatar
South, Michigan
Joined Nov 2009
I Use Minwax Polycrylic water based, mixed 50% with Rubbing Alcohol, and sprayed on with air brush.
Good luck
Rich`
Rich` is offline Find More Posts by Rich`
Old Nov 19, 2009, 12:49 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
If you need a filling primer, mix talcum powder in the un-thinned Minwax Polycrylic, but you won't be able to spray it with an air brush. I usually mix a lot of talc and it is kind of a paste like consistency. Brush or trowel it on. The talc gives it a pleasant small when you are sanding it too.
larryross is offline Find More Posts by larryross
Old Nov 19, 2009, 01:52 PM
MontoRC is offline
Find More Posts by MontoRC
MontoRC's Avatar
Powell Ohio USA
Joined Nov 2009
I've had luck with krylon H2o spray latex. They have a white primer in the h2o series. It says on the can that it paints craft foam. In a few cases of me being impatient and applying way too heavy a coat it has eaten the foam. I like it. I don't know if you'd consider it to be light weight though.
MontoRC is offline Find More Posts by MontoRC
Site Sponsor
Latest blog entry: Flight Test Photo
Discussion Mi primer vuelo y mi primer estampe cessna 182 pro parkflyers kenlider Mexico 2 Sep 28, 2009 06:14 PM
Discussion Primer for Parkzone Typhoon foam rperego Painting and Finishing Tips 1 Sep 22, 2009 07:16 PM
What Paint Primer To Use On Foam tinsink Foamies (Kits) 0 May 03, 2002 09:55 PM
Foam Safe light Sandable Primer S Anastasio Foamies (Kits) 1 Feb 02, 2002 08:40 PM
Foam Primer/Sealer FBergski Foamies (Kits) 1 Sep 08, 2001 05:02 PM
