Old Jun 03, 2003, 11:12 PM
Wollongong, Australia
Joined Feb 2003
Switchback C of G question.
The Switchback Sport manual says to check the CG by holding the plane on two fingers at the fuselage, and it should balance on the spar to approx. 1/4" behind the spar. However it seems easier to just pick up the plane by the wingtips, with one finger on each tip.
Is this a valid way to check the CG, I imagine it is, but does the 'spar to 1/4" ' rule still apply? If you check your SB this way, where does it balance?
Thanks, Bernie.
bernie01 is offline Find More Posts by bernie01
Old Jun 04, 2003, 04:33 AM
Goodychrischild's Avatar
Bristol, UK
Joined Oct 2002
As this is a straight wing ie not swept, then the CG will be in the same place at the tips, however I would suggest that you just turn the SB upside down, then it is easy to balance at the root of the wing.
Chris
Goodychrischild is offline Find More Posts by Goodychrischild
C/G question ZB50 The Profile Brotherhood 6 Jun 06, 2003 02:03 PM
Kwik-E C of G question Al P Sport Planes 3 Apr 14, 2003 07:32 AM
Beaver C.G. question Moviemaker Parkflyers 9 Mar 16, 2003 07:08 PM
Switchback C.G. Question cfossa Parkflyers 8 Jan 03, 2003 05:48 PM
Yet Another C.G Question Heather Modeling Science 3 Aug 19, 2002 09:59 PM
