Old Jul 22, 2016, 06:02 PM
congcon97 is offline
Find More Posts by congcon97
Joined Jun 2007
How charging upto 4.20 volt per cell? Help Please. !!
Guys,
How can I charge my lipo and Lion cell upto 4.20 V?
All the chargers I have are charging a single cell upto 4.17 V only.
I need more juice for my applications. I am ok with the safety.
I use these 2 chargers.
https://www.xtardirect.com/products/...iant=529941637
https://www.google.ca/search?hl=en&s...L-8cohm6CpM%3A
congcon97 is offline Find More Posts by congcon97
Old Jul 22, 2016, 09:18 PM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Hardly enough to make a difference. Maybe a few seconds run time.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jul 22, 2016, 10:57 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Roger on that. That few hundreds of a volt is meaningless as most packs when charged to 4.2V drop to that level after being removed from the charger.
That amount of energy is not going to give you "more juice for my applications".
hoppy is offline Find More Posts by hoppy
Old Jul 24, 2016, 02:01 PM
Joined Jun 2007
Cell phone's battery charges upto 4.20 even more I see. I mean like 4.23 or a little more . How that happens?
Old Jul 24, 2016, 02:08 PM
kamcoman is online now
Find More Posts by kamcoman
Douglasville, GA
Joined Sep 2004
Magic!
kamcoman is online now Find More Posts by kamcoman
Old Jul 24, 2016, 04:09 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Magic indeed. My guess it's a small change in battery chemistry.
I know, use that cell phone charger that goes up to 4.23V......but then you'd need the lipo cells used with that charger. Never a simple solution.
The part being ignored is how little energy is gained by going up a few hundreds of a volt. It's much safer to discharge 0.05V more than normal to get additional flight time. No matter how you charge your packs, you are not going to get more zio, a very little more flying time but no performance gains to speak of. But it will decrease cycle life.
Old Jul 24, 2016, 05:48 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The cell voltage coming out of my charger is usually at 4.17 volts, which is fine with me. The Echo 6-10 chargers that I use, enable you to go into the programming and fine tune the full voltage output to 4.2 if I wish. I'm happy where it is.
Another point. I don't normally balance charge unless the cells get too for out of wack, then I balance. I still plug the balance in so the charger can keep track of the individual cells. If one cell goes over the 4.2 by a couple of tenths, it will start bleeping and give a warning on the screen.
Had this happen where, without the balance plug plugged in, a poor cell will not come up equal to the rest, and the cell that is already at 4.2 will start climbing , trying to get the pack up to 8.4, if a two cell pack, and will catch fire from over voltage.
Found that out the hard way.
Gord.
Old Jul 24, 2016, 05:51 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
How accurate is that voltmeter the charger uses? If you have another voltmeter, check what it reads versus what your charger reads.
Rodney is offline Find More Posts by Rodney
Old Jul 24, 2016, 06:15 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Done that with a VOM, but it's a good point.
Gord.
Old Jul 24, 2016, 08:38 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
My charger is set to end at 4.15v so your batteries are charged more than mine
600Bob is offline Find More Posts by 600Bob
Old Jul 24, 2016, 09:18 PM
Joined Jun 2007
Gord.
I like that your charger can charge upto 4.20 volt per cell. That's how li-on/Li-po is advertised to be fully charged. Doesn't matter life cycle man ...technology changes too fast to think abt a silly battery life cycle. All I care abt more juice.
U can program your charge ending voltage upto how much?
Old Jul 24, 2016, 09:46 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
don't really know. Never went any further than that. and wasn't concerned with anything higher than that. I don't know why you'd want anything higher than that. When I get a minute I'll check it out.
Gord.
Old Jul 24, 2016, 10:47 PM
Joined Jun 2007
Gord.
No, I wnt just upto 4.200 volt only;not more than that for sure.
Does your charger do so? Give me the link of that pls. Buddy, we r from same province by the way.
Old Yesterday, 05:39 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
http://www.hobbyking.com/hobbyking/s...er_w_acc_.html
These are the ones I use. I see they are out of stock right now. It's sort of a generic charger. The Accucell 6-10 is pretty much the same charger and will do the same thing.
I've used these for many yrs with no problems.
The pair of them are going steady at the field run off a generator with a 110 volt power supply.
Where do you live?? Any where close and you should come to our funflies.
Gord.
Old Yesterday, 05:53 AM
Jaketheone46 is offline
Find More Posts by Jaketheone46
Jaketheone46
United States, KY, Florence
Joined Nov 2014
The reaktor 250&300 and any icharger will let you set your charge termination voltage all the way up to 4.3v per cell.
Jaketheone46 is offline Find More Posts by Jaketheone46
Question 12v AGM battery: how many volts per cell when charging? Bird09 Batteries and Chargers 3 Nov 03, 2015 04:34 PM
Discussion best volt per cell for accurate IR reading??? flysohigh Batteries and Chargers 21 Oct 19, 2015 09:19 PM
Discussion Auto-charging to less than 4.2 volts per LiPo cell Jim_Marconnet Batteries and Chargers 3 Jan 14, 2008 09:02 AM
Discussion Robby lipoly 400 only charges upto 4.16V / cell u4eake Batteries and Chargers 4 Nov 04, 2007 04:51 PM
Question How bad is 4.25 to 4.28 volts per cell Flyextreme Batteries and Chargers 2 Oct 05, 2007 11:16 AM
