Old Mar 18, 2016, 08:05 AM
Tango Juliet is offline
Find More Posts by Tango Juliet
Returning From Hiatus
Tango Juliet's Avatar
Mobile, AL
Joined Aug 2006
Help!
Detailing an APC or MA Propeller for Scale?
I'm interested in learning the best approach to detailing an APC or Master Airscrew propeller to provide a more scale appearance, whether it be shiny metal, painted for color, or just various tip markings. In the same vein, what about detailing a wood prop? I know there are some already commercially available wood props for WWI and Civilian scale, but not in the smaller diameters.
Explain your process and provide photos if you can please. Thanks in advance.
Tango Juliet is offline Find More Posts by Tango Juliet
Old Mar 18, 2016, 09:26 AM
buzzltyr is offline
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Pat Tritle has discussed painting scale props in many of his build threads. He has put the basics of what he does here:
http://www.patscustom-models.com/pai...caleprops.html
Mark
buzzltyr is offline Find More Posts by buzzltyr
Old Mar 18, 2016, 10:19 AM
Mobile, AL
Joined Aug 2006
That's a start. Thanks.
Old Mar 30, 2016, 11:44 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Recommend whatever method you use, save the scale prop for display and use stock props for flying. I once did a fairly decent job of applying chrome Monokote to a wooden prop and adding a tiny prop manufacturer's label and painting the tips to match the scale model. You can scrub chrome Monokote with Scotchbrite pad before applying with the iron, to dull the mirror finsh if wanted.
E-Challenged is offline Find More Posts by E-Challenged
New Product With our Dismountable APC/MA propeller makes your plane looks more real ! aeo-tiffany Scale Kit/Scratch Built 5 Dec 17, 2015 10:31 AM
Wanted Xoar 26x12E or APC 26x13E Propeller yellowbird2800 Aircraft - Electric - Power Systems (FS/W) 0 Oct 18, 2013 11:41 AM
Sold Large lot of new and used propellers - MA, TF, APC kdk3187 Aircraft - Electric - Power Systems (FS/W) 1 Oct 05, 2012 05:39 AM
APC, Zinger, MA, Kavan, Wood, Nylon, Karbon Propeller Diffirences okan Power Systems 4 Dec 02, 2010 05:01 PM
Will trade an APC 10x7 for an APC 10x7 slowflyer cruzomatic Aircraft - Electric - Airplanes (FS/W) 0 May 11, 2002 12:17 PM
