Wireless Simulator Control with Jeti Radio
If you prefer to practise flying on sims with your "real" radio, you may be used to connecting your transmitter to your PC with a USB cable and matching trainer port plug. With today's technology we can forego the wires and control the sim wirelessly making life just a little easier...
Fly Realflight on your Jeti radio without any wires
If you prefer to practise flying on sims with your "real" radio, you may be used to connecting your transmitter to your PC with a USB cable and matching trainer port plug. With today's technology we can forego the wires and control the sim wirelessly making life just a little easier. Here's a how-to for getting wireless control of Realflight using a Jeti Duplex radio system.
1. Purchase the Jeti interface cable
You'll need a cable to connect to the PC interface. There are two versions, a square style plug for connecting to the Interlink controller, and a round plug for connecting to the wired interface cable. These cables can be found on the Esprit Model webpage here.
2. Receiver and Power
You'll need a Jeti receiver for the transmitter to talk to. No need for anything fancy so just go with the R4i here. You'll also need a 5V source to power the receiver. You could use a standard receiver battery, but since the unit will be near your computer, you could modify a USB cable to power the receiver and never worry about running a battery down.
3. Radio Setup
Once you bind the receiver to your radio, you'll need to go into the menu to the Device Explorer screen. Click on your receiver and change the Serial Link to say PPM Positive. Set the output period for the PPM output of the receiver to 20ms. This allows it to talk properly to the computer.
4. Final Steps
Connect the interface cable to the receiver and to the Interlink controller or interface cable and power the receiver. Run Realflight and go to the Simulation menu and find the Select Controller button. Click it and choose JR, then click Edit to create a new profile in the software. You may want to make separate profiles in the radio and software for Airplanes and Helicopters. Now you can map the channels to the software and you are on your way to wireless simulator fun.
Old Mar 02, 2016, 08:50 AM
MartMX is offline
Find More Posts by MartMX
Gettin' back into flyin'
MartMX's Avatar
United States, FL, Escambia County
Joined Dec 2012
Wireless makes flying the simulator much more convenient. I did this with my Taranis and AeroFly a couple of years ago....
http://www.rcgroups.com/forums/showt...7#post27071300
MartMX is offline Find More Posts by MartMX
Mini-HowTo Using the Jeti DS-16 with a Realflight or Phoenix Computer Simulator drjay Radios 5 Jan 30, 2016 03:35 AM
Sold Realflight 7.5 Simulator w/ Wireless TX! BNIB.......$100 shipped whiplash1 Aircraft - General - Miscellaneous (FS/W) 7 Nov 09, 2015 03:06 PM
Sold RealFlight R/C Flight Simulator with Interlink Plus Controller zeroin1shot Aircraft - General - Miscellaneous (FS/W) 0 Jan 08, 2015 03:22 PM
Sold RealFlight G3 Simulator with Controller, Expansion Pak 1, and box $48 Shipped nordby Aircraft - General - Miscellaneous (FS/W) 2 Jun 22, 2014 05:04 PM
