Old Mar 19, 2015, 09:15 PM
tom_nichols_f4 is offline
Find More Posts by tom_nichols_f4
tom_nichols_f4's Avatar
Joined Jan 2009
Twisted Hobbys Edge 540 Mini ......"Two is better than one"
Edge 540 Mini
Description:
Hey all you 3D junkies out there. I have something thats definitely worth checking out. Its the brand new Edge 540 Mini. The scheme and lines of this thing really stand out. It honestly has to be one of my favourite looking profiles to date. The race checker scheme, the winglets, and the bright colour choice's of yellow or red really make this one pop. But not only does the New Edge Mini look good, its also a great flyer. It would be a great addition to anyone's fleet. Be it the beginner just learning to 3D or the 3D huckn veteran.
[/SIZE]
Specs:
Wing span 24 / Length 25
AUW 90 - 100g
Required components:
2000-2350kV Out-runner motor (12g 14g)
6A ESC
2s 180 250mAh battery
Micro Receiver
(2) 3.5g servos
4.0g servo
Prop: 6x3 to 7x3.5 GWS DD
Glue
INFO:
Description:
http://www.twistedhobbys.com/TH-24-E...ge-540-Red.htm
Description:
http://www.twistedhobbys.com/TH-24-E...540-Yellow.htm
Now the Big Decision ... What colour?. Good thing I was fortunate enough to receive one of each as deciding between the two would of been tough. So in my case I think I will just end up picking the colour that better suits the flying style of that day. Say mellow yellow for those low and slow harrier and torque rolling days. And Fire Red for those high speed, high energy knife edge flights. Ok its time to get started !
Description:
Building the Edge 540 Mini is pretty straight forward as the Instructions are very detailed and well laid out. I ended up following them to the tee and was able to complete both builds in a couple of days. Double the work though but twice the fun!. Here are just a few pics I took through out the process to give you an idea of what you'll be getting into.
Build pics:
Description: Name: 2nd.jpg
Description:
Description: Name: 4th.jpg
Description:
Description:
Once the building portion was completed it was time to set them up and take them outside. I started with the radio and set them up with 3 different flight modes. This gives 3 different animals to play with. A mild mannered setting for slow rolling circles and precision flying. My go to medium 3D rate which i tend to do most of my flying with. And then last but not least the crank things up and surprise yourself 3D rate.
After setting up the radio the next thing was to tackle the C.G.. I went with the suggested 150mm back from the motor mount which I found gave a good all around neutral feel. Surprise, surprise, they had already figured out the best C.G. location, no thinking required ;-).
NOW FINALLY! ......the only thing left to do was to charge up some batteries and see what this thing could do :-).
Flight Report Time:
First off I would like to comment on how stable this thing is in high alpha for its size. I found it to be rock solid in both upright and inverted harrier's with little to none wing rock. This feature would definitely appeal to anyone just learning to harrier . Hovering I found to be docile and predictable with minimal correction changes needed to keep it there. Knife edge flight needed zero coupling once the C.G. Had been set up properly. Rollers, snaps, snap turns, and walls were very typical of a light foamy with no surprises.
I must say I enjoyed flying the Edge 540 a lot and shows with the big grin I had after every flight.
Description: Name: IMG_5792.jpg
Description:
Description: Name: IMG_5834.JPG
Description:
Video to come Soon!
tom_nichols_f4 is offline Find More Posts by tom_nichols_f4
Joined Jan 2009
Video Up.
Twisted Hobbys Edge 540 Mini (3 min 17 sec)
Tom
Old Mar 19, 2015, 09:20 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
very cool shots with the mountains in the background
cdee
cdee is offline Find More Posts by cdee
Old Mar 19, 2015, 09:21 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
When you can fly a plane on the maiden and second flight and do whatever you want, you know you've got your hands on one of Twisted Hobby's finest new products. Really easy to fly and yet very capable of all the high energy stuff. This plane will be at Nall and everywhere else we go this year. Love it!
TWISTED ENERGY THE EDGE 540 MINI (2 min 13 sec)
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Mar 20, 2015, 06:40 AM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Awesome photos and build Tom, looking forward in seeing you ring out the Mini Edge 540's
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Old Mar 20, 2015, 07:38 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Had my MIni Edge 540 out in the park last night, not ideal conditions, was kinda cold and breezy, but the little Edge handled it all just fine. CG from the manual was spot on.
Setup of the radio was super simple... 100% on all the ATVs with the stock arms and outer hole locations. Initial setting for expo are 60% on the ailerons and 50% for both the rudder and elevator... may tweak that a little in the next couple flights. On the 250mAh sized 2s packs I was getting a solid 3-1/2 minutes of hard throttle, with some capacity to spare.
This plane will be at home just about anywhere... should make a good Gym Flier, Backyard Basher or Park Performer. It is really nice that it is so small, easy to transport, and with a pocket full of batteries you can have a fun filled afternoon at your favorite flying venue.
cdee
Old Mar 20, 2015, 10:31 AM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Nice reports on the new mini guys. The scheme is different too (I like it).
KamikazePilot is offline Find More Posts by KamikazePilot
Old Mar 20, 2015, 02:17 PM
darticus is online now
Find More Posts by darticus
United States, NJ, Sparta Township
Joined Mar 2007
Very nice flying! Is there a comparison between the other mini's from TH? Is this slower faster or what? Very Very Nice. Ron
darticus is online now Find More Posts by darticus
Old Mar 20, 2015, 09:22 PM
Benton3dflying is online now
Find More Posts by Benton3dflying
Team Twisted!
Benton3dflying's Avatar
Joined Aug 2012
Awesome shots! The plane looks great!
-Benton
Benton3dflying is online now Find More Posts by Benton3dflying
Old Mar 20, 2015, 10:00 PM
perryleslie is offline
Find More Posts by perryleslie
perryleslie's Avatar
United States, SC, Columbia
Joined Mar 2011
perryleslie is offline Find More Posts by perryleslie
Old Mar 20, 2015, 10:41 PM
TEAM TWISTED
Joined Dec 2011
Slower or faster... depends on the stick on the left
Ron, same power system and nearly same exact size planes... The Edge is a better, more stable plane for those starting into 3D flying. The classic clean straight leading edge adds to it's stability in the air. It's going to be a little easier to fly than other 24" planes. That was the intent anyway. A little less roll rate than the MXS-C Mini and a little less snappy but plenty of authority to do all your 3D maneuvers (like waterfalls, knife edge loops, rolling maneuvers etc...).
Latest blog entry: An IMAC EVening from the DJI P3
Old Mar 21, 2015, 07:50 PM
TEAM TWISTED
Joined Dec 2011
Here's a little video showing a peek at how slow and fast it is.
Well behaved plane and a lot of fun. I know... they're all fun!
Who says you can't fly planes in the woods..
Mini Edge 540 Trailer 2 (2 min 10 sec)
Old Mar 21, 2015, 10:03 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
fun video... great flying...!
cdee
Old Mar 22, 2015, 03:12 PM
TEAM TWISTED
Joined Dec 2011
Thanks C Dee
Tom's video above just posted in the reserved slot. Sweet gym and the outdoors vid looks like it's in the Alps or something. Awesome scenery for sure! More
Old Mar 22, 2015, 06:36 PM
Joined Mar 2011
Cool video in the woods�� I liked the takeoff from the tree. The new color schemes are awesome and love the checkerboard paterns.
Discussion Twisted Hobbys 24" Mini Edge 540 flydynamics 3D Foamies 16 Mar 30, 2015 09:58 AM
For Sale Twisted Hobbies EPP Edge 540 Red Scheme BNF <<LPU<<CA ED3 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2015 12:19 AM
Sold Twisted Hobbys 32" EPP Edge 540 HB (Blue) + Motor: BNIB os2 Aircraft - Electric - Airplanes (FS/W) 1 Nov 17, 2014 07:38 PM
Sold Twisted Hobbies Two Mini Crack Yaks - One new in box, other with power package $120 nordby Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 09, 2014 12:58 PM
Sold Twisted Hobbies Two Mini Crack Yaks - One new in box, other with power package $120 nordby Aircraft - Electric - Airplanes (FS/W) 7 Sep 08, 2014 11:17 PM
