Old Mar 25, 2013, 10:43 AM
Joined Aug 2012
Steigeisen Lift
I just got all my components that were back ordered... is there a link to a build log anywhere? Getting ready to jump into it!
Air.Stormer is offline Find More Posts by Air.Stormer
Old Mar 25, 2013, 11:26 AM
Joined Jul 2012
I haven't come across a Steigeisen Lift build thread on my searches but let's take it from here. I hope to be receiving mine in a week from now. Ordered directly from Stratair:
http://www.stratair.com/Shop/Produkt...spx?ArtID=1365
funkz is offline Find More Posts by funkz
Old Mar 25, 2013, 11:51 AM
Joined Aug 2012
Mine will be a work in progress... I have questions with layout of components and ways to go about it before I secure them and shorten wires.... Tough to do with not knowing cg and such. I will try to ask the questions and see what would be the best way to get around them. I will take my time but it seems with the servos in the wing already and only two servos to install shouldn't be too long to get her airborne. I will be on vacation for the rest of the week but start at it hard next week....
Old Mar 25, 2013, 01:56 PM
Soarster
Canada
Joined Jun 2009
Air Stormer,
Have you checked out Skip's site lately? I see a link on his Steigeisen Lift page to a nice instruction manual, and the recommended CG is 73 mm +/- 1mm.
Good Luck,
Paul
Paul Harvey is offline Find More Posts by Paul Harvey
Old Mar 25, 2013, 07:50 PM
Joined Oct 2011
The link on the Skip Miller site is to the May 2009 instructions for what is now called the Steigeisen Race. (just finished 2 of them for the 2013 contest season) My guess is 73 mm would be a good place to start but be prepared to move it back. I fly my Races between 77mm - 80mm.
GeorgeB3 is offline Find More Posts by GeorgeB3
Old Mar 25, 2013, 10:07 PM
Joined Aug 2012
Yep...I noticed it was for the race model... Has the 4 servos mounted in fuse. I will just pick a number and go for it!
Old Apr 03, 2013, 07:22 AM
Joined Jul 2012
Hi Air.Stormer, how's your build coming along? I just received my SE LIFT and will try to get all needed components to start building it but unfortunately the wing came with some defects. I will be posting pics later on to get some comments/advice as on how serious they are.
Have sent an email with pictures to Logo-Team to get their word before I start building.
Also, on the right side where the peg should be located, it has a very particular bump (like a small air bubble) this means perhaps more epoxy on the area. Do you see something similar on your wing and have you already installed the peg?
Old Apr 03, 2013, 07:35 AM
Joined Aug 2012
I was just laying all the parts out last night... I will take some pics! I will be trying to complete this week as I would like to chuck it this weekend!
Old Apr 03, 2013, 08:11 AM
Joined Jul 2012
I'm also looking fwd to get to fly it this next weekend. Here attached are the pictures of how the wing arrived. There's a very small crack on it, not visible on this pics. I'm sure it can fly but is not so cool to receive it this way.
Stratair Logo-Team send me a report so to be able to claim the insurance through DHL but I was told is not me the recipient who opens the claim but the one who payed for the shipping...
Few more pics are here:
https://plus.google.com/photos/11776...CLW94P2glJzZWA
Old Apr 04, 2013, 05:51 PM
Joined Jul 2012
advice
Hi again.
While DHL and Strata decide what is there to be done regarding the wing I decided to prepare the fuselage and need some advice regarding the already (factory installed) pushrods. They come in a very clean way, it took me a couple of hours on a Stobel to fish the teflon thread while here is just a question of shortening them to get to the servo horns.
I'm a bit puzzled cuase one looks carbon and the other one is steel(?). Also as you can see on the pics my servos are not yet linked so any advice before gluing the servo tray to the fuse is appreciated. (distance to front including battery pack and receiver is already measured).
Air.Stormer, how did you solved this one?
Old Apr 04, 2013, 06:53 PM
1900 Driver's Avatar
Denver CO
Joined Mar 2009
Use the carbon rod for rudder and steel for the elevator. The elevator doesn't have much space and once you make the zbend and install the belcrank there's really no turning back and you don't want that to fail!!
Brandon
1900 Driver is offline Find More Posts by 1900 Driver
Old Apr 05, 2013, 01:48 PM
Joined Jul 2012
Got this good img from Stratair today, might be of use for future builders since is not on that pdf from 2009. Tx 1900 Driver for your reply.
Old Apr 07, 2013, 11:40 PM
Joined Jul 2012
Could anyone with a Steigeisen LIFT with "RDS" share the way to link the ailerons? I have received the 2009 manual but is for non "RDS" models... google img search shows RDS systems that differ from what I got on this wing; a 1.2mm L shape steel linkage that seems to require a horn but i'm unsure how to go about it since it needs to be installed on the inside.
I'm told by Stratair this:
"make a cut into the ailerons that you can install the CNC-servohorns"
--- edit:
Adding pics sent by Stratair
Old Apr 12, 2013, 09:45 AM
Joined Jul 2012
extra aileron portion
Hi again, I head tomorrow for a maiden with the Steigeisen, will appreciate any advice regarding that extra aileron portion that can either be taped to the outside so to block it or to the inside, to the aileron so to add and make it longer.
Could someone comment on this portion of the wing and its reason to be there.
Thanks in advance!
Old Apr 12, 2013, 01:02 PM
Denver CO
Joined Mar 2009
I tape mine so that they are fixed! Im not much a traileron fan. Flies just fine like that!
Sold Droidworx AD-6 Heavy Lift Frame Good Condition Talajouy Aircraft - Electric - Multirotor (FS/W) 3 Jan 19, 2013 10:45 PM
Build Log HexaKong XL-6S Heavy Lift 950mm Hexacopter w/16" Props Z06 Tony Multirotor Talk 20 Jan 12, 2013 11:43 PM
Discussion Lifting tail on 3d plane? Kirbymcrae Electric Plane Talk 16 Jan 06, 2013 12:37 PM
Discussion Steigeisen Lift from Skip Miller Models cody303 Hand Launch 19 Nov 30, 2012 12:17 PM
