Old Jul 21, 2014, 10:13 PM
Joined Jun 2014
Question
Flight Time
I am looking for ways to increase the flight time on my quad. I am using the Turnigy talon V2 frame with 1100kv motors, 3s battery, and 9x4.7 props. Originally I was getting around 10-12 minutes of flight time. Now that I have added a Mobius camera with a gimbal and my fpv gear, flight times are shorter. Is there anyway to increase the flight time? Could I switch to a lower kv motor and use larger props or would that have an adverse effect? Thanks.
JYount is offline Find More Posts by JYount
Old Jul 22, 2014, 12:02 AM
Godless Heathen
United States, LA, New Orleans
Joined Jan 2014
Lower KV motors with bigger props @ 3S, or same props w/lower KV motors @ 4S. Also, you don't mention the size battery you're using; you may be able to go up in MAH with the same setup to regain some flight time.
For that 550-size frame, seems like 1100kv is a little high to begin with. Even a little Phantom uses lower KV with 3S. If you want to stick with 3S, 800-900KV motors would turn 11 or 12-inch props no problem, and you could use a 5 to 6000+ MAH battery to get the flight times you want. Same motors with 4S 5000MAH and your 9047 props might even get more.
fartnokker is offline Find More Posts by fartnokker
Old Jul 22, 2014, 03:59 PM
Joined Jun 2014
Thanks for the info. I am currently using a 3000mah battery, but would the 5 to 6000 mah battery increase flight time even with the added weight? I have two 3000 mah batteries I will wire in parallel and see what that gives me.
Old Jul 23, 2014, 04:43 AM
GhostMaster's Avatar
Portugal
Joined Feb 2012
Check the new multistar lipos on Hobbyking... 5200mah with 320g is what you need to get 14/15min
GhostMaster is online now Find More Posts by GhostMaster
Old Jul 23, 2014, 05:28 AM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
Yes use a 10C battery to see some puffing action
deno6031 is offline Find More Posts by deno6031
Old Jul 23, 2014, 08:21 AM
Joined Jul 2014
what is your auw?
Channel5 is offline Find More Posts by Channel5
Old Jul 23, 2014, 08:56 AM
Portugal
Joined Feb 2012
? Why 5200mah at 10C gives 52A constant. Its enough for 350/450 size quads...
If you need more use the 4S 5200mah.
Old Jul 23, 2014, 04:06 PM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
Should be enough if you were only hovering with an empty 450class quad, which is not the case here, we are talking about a fully loaded 450class quad with a brushless gimbal, and my guess is that he would do more than just hovering. He will have much higher peak currents than 50-60amps.
My 500class quad is puffing my 5000mah 30c 4s lipos, but I fly mostly max throttle
Old Jul 23, 2014, 04:39 PM
Portugal
Joined Feb 2012
That not true but i will not argue with you. Most 450 size quads dont take more than 20A hovering arround...
Or you have some rocket ship there...
Discussion Which gives the longest flying time. Fastforward flight or hovering flight?? Pakingzzz Electric Heli Talk 18 Feb 04, 2014 10:29 PM
Discussion Formula for longer flight times rcmaverick Electric Plane Talk 191 Sep 29, 2013 10:35 PM
Question Theoretical flight-time -vs.- practical Flight-time vineet_p Multirotor Talk 16 May 26, 2012 12:49 PM
Discussion Twinstar battery configurations and flight time. Whats your flight time? learninginverted FPV Talk 2 Dec 13, 2010 07:05 AM
