Old Apr 09, 2004, 04:58 PM
Tlh
CA
Joined Apr 2004
lipoy uses?
Curious? What requirements are there for Lipoly cells? ie - must you use a special ESC ? Will the lipoly work with standard can speed 400 motors? I know that the brushless motor requires that you use a brushless ESC? Can I use lipoly on either brushless setups or standard can? Thanks
Tlh is offline Find More Posts by Tlh
Old Apr 09, 2004, 05:26 PM
Just fly the darn wing!!!
ScYcS's Avatar
Germany, NRW, Herford
Joined Oct 2003
You can use the Lipo packs in either brushed or brushless environments. Your ESC should be equipped with a low voltage cutoff, preferrably with a programmable one. The cutoff should be set to 3v per lipo cell, eg. 6v for a 2cell pack. If you have a non programmable ESC, then make sure you know the cutoff voltage and make sure you don't run the lipos too far down. If the plane begins to start losing power, land quickly.
ScYcS is offline Find More Posts by ScYcS
Old Apr 09, 2004, 06:35 PM
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
10C 1500 MAH LIPOLY = 15AMP SERVICE
5C 1500MAH =7.5 SERVICE
MEASURE CURRENT DRAIN ON PLANE WITH NICAD OR NIMH USING
AMP CLAMP OR WATTMETER
CHECK C RATING OF PACK BEFORE RUNNING OR RESET THE THROTTLE TO 50% ON A DIGITAL TRANSMITTER
hall woo is offline Find More Posts by hall woo
