Old Jul 12, 2005, 03:28 AM
werty is offline
Find More Posts by werty
Casino, Australia
Joined Sep 2002
Problem with CC45 and AXI2820/10
I have a new AXI2820/10 and CC-Phoenix45 that keeps cutting out at very low rpm.
When you start applying throttle the motor spools up and according to the whatt meter gets to around 45-50 watts and then cuts out. Vlotage at cutout is approx 11.8v and amps is approx 4amps.
The following is my setup
Prop 11x6 folding prop (MPJet 40mm spinner and graupner cam blades)
Battery 3S2P 2600 Polyquest
The settings I have programmed the C45 with are as follows;
Cutoff voltage 9.0v (option5)
Current Limiting standard (option3)
Brake soft delayed (option1)
Throttle auto calibrating (option1)
Electronic Timing Advance Standard (option2)
Cutoff Type Hard (option1)
Soft Start (option2)
PWM Switching 11kHz (option1)
Any suggestions as to what might be wrong would be greatly appreciated.
Peter
werty is offline Find More Posts by werty
Old Jul 12, 2005, 10:44 AM
FredericG is offline
Find More Posts by FredericG
FredericG's Avatar
Belgium, Aalst
Joined Dec 2002
You could lower the cutoff voltage (just for testing and while you are closely monitoring the voltage) or select soft cutoff to see if it is the LVC that kicks in.
What happens without prop?
Fred
FredericG is offline Find More Posts by FredericG
Old Jul 19, 2005, 08:13 PM
werty is offline
Casino, Australia
Joined Sep 2002
Didn't have any luck with solving this problem by changing settings, looks like it was a LVC problem.
I ended up purchasing the Phx Link and updating the software in the controller which fixed the problem.
Shame to have to spend extra dollars to fix the problem but i guess no I have it I can make the most of my CC controllers by keeping them all up to date.
Peter
Old Jul 19, 2005, 09:11 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
It is also nice to be able to look at your settings on a computer screen instead of listening to beeps!
Jim
BrunswickOH is offline Find More Posts by BrunswickOH
Question Problem with programming 55-10-32 Hard Case Kontronik 1 Jul 28, 2006 10:45 AM
Problem with older Phoenix 10 and "Little Screamer" Iain Castle Creations 7 Sep 20, 2005 02:32 AM
Problem with PJS550 and Tsnami 10, HELP? peterg Batteries and Chargers 1 Apr 13, 2004 03:21 PM
UH OH, foam problem with my new A-10, Mr Lin, do the right thing..... Impreza GWS (Grand Wing Servo) 7 Jul 06, 2003 07:08 AM
Intresting problem with Logo 10 Rotor Hub wayne Electric Heli Talk 0 Apr 17, 2002 07:50 AM
