Old Mar 10, 2015, 07:17 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Build Log
Syner J Foam Build
Here we go.... A bagged version of the airfoils Gerald published here:
http://www.rcgroups.com/forums/showt...6&highlight=gt
It will be a three panel wing, with the first break at the inboard flap. It's only about a 44" center panel, but it simplifies the build for me and will also fit on my pylon fuse.
Hopefully, the plane will finish in the low 50 oz range.
After about two days of XFLR to Cad to foam cutter software, I started to build the foam beds that will support the airfoils (to maybe within a county of accuracy).
All said these pictures are about a week of work.
heliwill10 is offline Find More Posts by heliwill10
Old Mar 10, 2015, 07:32 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
End Caps
I used Profili and my neighbor's CNC to cut the endcaps. They are 5-ply birch from balsa USA.
Like the foam beds, this took a day of tinkering to get everything lined up perfectly.
I know, I know, I should be doing molds....
Old Mar 10, 2015, 11:39 PM
VHO is online now
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Now that's an interesting way to build the spar. Wrapping in-situ rather than bagging the spar first is new to me, please tell me more.
For example how many layers of UD (I presume its not constant across the span) and I presume you leave the finished thickness less than the full thickness of the spar slot so you can cap it with balsa or foam or filler. How do you do the maths to compute the final thickness?
Do you intend to winch the finished toy, or is it for F5J (or Ales)?
Looking good, love your workmanship. Its top notch.
Hutton
VHO is online now Find More Posts by VHO
Old Mar 11, 2015, 02:05 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Australia, QLD, Gold Coast
Joined Sep 2008
Very nice build techniques
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Mar 11, 2015, 07:21 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Thanks for sharing the build Will. I love to see these come together from bits off foam and wood, fabric and epoxy. Fascinating!
aeajr is offline Find More Posts by aeajr
Old Mar 11, 2015, 10:05 AM
killercando is offline
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
killercando is offline Find More Posts by killercando
Old Mar 11, 2015, 12:44 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Mylar and fabric.
I'm using the carboweave CW30 for skins with an extra doubler on the flaps.
The Mylar is split for the top and one piece for the bottom. The Mylar from CST is my favorite, it's really makes for a shinny finish.
I use frekote for the release. Here's what I've learned about frekote:
1. If your part feels tacky, throw the can away.
2. If the parts just didn't come out like normal, throw it away.
3. Always test your paint glue combo
4. Do a tape test, if basically any tape sticks to the surface, throw it away.
5. I can't find an expiration date on the spray cans....
6. I've never been comfortable going up to the expriation date on the liquid cans.
With all that said.... I've never had a part stick. (Knock on wood) I really do love the stuff.
Old Mar 12, 2015, 06:46 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
I'll edit my grammar in a bit so bear with me
Straight forward bagging. I found that laying down the carboweave down dry is the best. Normally, I wet the mylar and drop the fabric on, re-positioning CW is really difficult.
After the fabric is wet, I debulk the skins for about 5 mins. That gives me enough time to wet the leading edge, hinge and fiberglass facing.
Pulling the bag over the dihedral is a little challenging, Its best to have the bottom bed with the wedge in place so the mylar is resting on something. I pull about 22" then position the beds. After everything is in place I remove the vacuum to give the weight a chance. Then I turn the pump back on.
Old Mar 12, 2015, 06:51 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Out of the bag, 12oz.
Tips are next....
Old Mar 12, 2015, 10:57 AM
blewis01 is offline
Find More Posts by blewis01
that's gonna hurt...
USA, CA, San Jose
Joined May 2005
Very cool and beautiful work. Thanks for sharing.
Bruce
blewis01 is offline Find More Posts by blewis01
Old Mar 13, 2015, 04:58 PM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
This will be a TD ship.
I use a excel sheet from Anker to determine the spar layup. I have been using 9oz T700 uni, to get something lighter I went to the IM7 6oz. with a similar layup. The foam is hi-load 60 and the wrap 3K plain weave on the bias.
Here's the tapers for the center panel:
Top Cap:
3 full layers
36"
29"
24"
22"
12"
Bottom Cap:
2 full layers
36"
24"
22"
18"
12"
Tip layup:
Top & Bottom Cap:
1 full layer
28.5"
16.5"
Hutton
Old Mar 14, 2015, 03:20 PM
Chuchuf is online now
Find More Posts by Chuchuf
Joined Aug 2009
As you noted once the Carboweave gets wet with epoxy resin, the binder disolves and repositioning can be difficult if not impossible.
I generally wet my mylars and have some help me when I put the CW on them. I just want to be sure I have good saturation, but I'm sure your method of wetting out works good as well as long as you get good saturation.
I've made leading edges on DLG's with CW and 3/4 ox class cloth similar to what you do. I put the class on the outside to give me a sanding guide so I know when I'm hitting the carbon. I generally 3M77 it in place.
I'm thinking of using some foaming agent with resin on leading and trailing edges (overhang past he foam) on future builds.
Nice work on your new plane.
Terry
Chuchuf is online now Find More Posts by Chuchuf
Old Mar 17, 2015, 07:52 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Wingtips
Same build process. The tips finished at 7.9oz. That puts the total wing weight around 28oz.
The spar layup seems plenty strong even for a moderate winds. The last panel is supported by UHM 100gr uni along with the dihedral break. That area has some pretty high stresses, I extended the wrap just past that point.
You can see the panels line up pretty well. I wanted to do square joiners, but the alignment would be really tough. One good thing about the round joiners they limit the stress on the joiner box on landings. Since the center panel is so short that might be a good thing.
Terry is sending more carboweave, I'm just shy of finishing the other side. Another couple days work to go!
Build Log Sig J-3 Cub Build GabrielSPeixoto Scale Fuel Planes 15 Apr 27, 2015 11:05 AM
Discussion 43in FreeWing Piper J-5 Cub Cruiser PNP (EPO Foam) jobinseattle Beginner Training Area (Aircraft-Electric) 2 Feb 01, 2015 06:28 AM
Discussion Clausxpf/Air Sally J-35 Draken,Alpha/Beta build w/New foam shell & glass method AIR SALLY Scratchbuilt EDFs 1210 Oct 17, 2013 08:31 PM
A new 100% EPP foam Scram-Blur J-250 build/Q&A thread sylair Foamies (Kits) 48 Jan 22, 2005 02:22 PM
