Old Apr 23, 2014, 02:08 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Build Log
Twisted Hobbys 32" MXS-C...more backyard insanity is here!
Hello again my Twisted brethren!
It's that time again. It's been a while since we have had another plane in the same vein as the ubiquitous Crack Yak. We've upped the sophistication with indoor monsters like the Crack Yak Lite and Crack Laser, and brought things to an easy and precise pace with the SuperLite Crack Yak and Su-29. We've dominated gardens and backyard bush flying with the Crack Turbo Beaver, and gone to even greater lengths with a few larger models.
But we know that lots of you fly outdoors exclusively, and crave the high energy and durability of the standard models. So we've got a new model for you!
http://twistedhobbys.com/TH-32-EPP-M...-CW-Scheme.htm
http://twistedhobbys.com/TH-32-EPP-M...S-C-Orange.htm
http://twistedhobbys.com/TH-32-EPP-M...XS-C-Green.htm
Presenting the new MXS-C. Built in standard thickness foam, the MXS-C is the backyard XA monster you have been waiting for. Insanely stiff, this thing will hold up to the sick power of the 26 gram motor with a 9x4.7 prop on 2S, or to go absolutely nuts, you can swap to a 8x4DD prop and 3S and enjoy power that borders on irresponsible. Firewall the throttle and this freak stays rock solid!
The aerodynamics are fresh and unique as well. Built on the same formula that delivered the Crack Yak and Crack Laser, the MXS-C is the result of many prototypes and lots of experimentation. The elevator placement and size, fuselage shape, ailerons, and rudder have been optimized to deliver simply insane authority. Harder pitch changes, pinpoint spins, tumbles, and lightning fast snap rolls are all right at your finger tips alongside high speed racing turns and surprisingly precise tracking as well. This plane knife edge spins better than many wood airplanes! Of course, pull the throttle back and the plane settles right in, delivering gentle and precise harriers for learning.
Even though we have returned to our roots, we refuse to rest on our laurels! Through careful engineering, we have managed to place the servos in the tail. Short, tight, and precise linkages deliver awesome control response with no pushrod guides necessary. Of course, RCFactory's legendary quality and ease of construction are here to ensure your model comes out perfect. This is the easiest plane to build yet!
Also, this is the first standard model to include landing gear! Built similarly to the Lite series landing gear, it's strong, very light, and easy to install.
For success with your MXS, be sure to read the manual thoroughly, and check out post 3 for some build and set-up tips.
cwojcik is offline Find More Posts by cwojcik
Old Apr 23, 2014, 02:11 PM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Videos!
My teaser (full length feature on the way):
MXS-C Teaser (1 min 12 sec)
Benton's awesome flight:
Twisted Hobbys MXS-C Radio Control Airplane (2 min 53 sec)
Old Apr 23, 2014, 02:12 PM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
Set up and build tips
We offer two power combos for the MXS-C. The analog power combo is great for learning and 3D flying. But for extreme performance, the digital power combo is the way to go...it includes all digital servos, and the punchy 2206 motor. The absolute best power you can get is with a 3S 450 battery and a 8x4DD prop.
Cut the elevator bevel a bit deeper for extreme elevator throw. Use a straight edge and a sharp X-acto blade to carefully remove some material from the edges of the bevel.
For best geometry, install the adjustable links in the following positions on the servo arms.
Rudder arm:
Elevator arm:
If you are using the T-Pro servos, you can glue the double arms to the single arms to achieve the proper length. Wrap them with thread after you have glued them (not shown here).
Install the horns flush with the first surface of the foam...do not push them to full depth. This will give you the best leverage and throw. Flex the elevator full down while the glue for the elevator horn is still wet; this will ensure that the horn does not hit the fuselage.
Choose what side you will install the receiver on, and for that side, cut the tail brace truss short by 5". This will allow for good clearance on the wires. Glue this piece on the nose of the plane to stiffen the front:
Apply Blenderm tape to the hinge ends and around the motor mount legs to prevent them from tearing in crashes. This is very important. You will need to put down some welder before the tape will stick.
Once you are satisfied with your CG, cut a slot for your battery. This will help with lateral CG and make the plane fly a lot more true.
Old Apr 23, 2014, 02:13 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
PDF Build Manual
Initial Release of PDF Manual - 04/27/2014
http://www.twistedhobbys.com/media/MXS%20Manual.pdf
Manual Revisions and edits will be tracked in this post.. Enjoy
cdee
cdee is offline Find More Posts by cdee
Old Apr 23, 2014, 02:20 PM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
"we have managed to place the servos in the tail. Short, tight, and precise linkages deliver awesome control response with no pushrod guides necessary."
That is awesome!!!! Thanks!
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Apr 23, 2014, 02:21 PM
joker24458 is online now
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Subbed, looks awesome! Will definitely consider a second standard Crack series plane now.
-Andres
joker24458 is online now Find More Posts by joker24458
Old Apr 23, 2014, 02:29 PM
hone1er is online now
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Nice! Love the second scheme too!
http://www.twistedhobbys.com/TH-32-E...XS-C-Green.htm
hone1er is online now Find More Posts by hone1er
Old Apr 23, 2014, 02:38 PM
joker24458's Avatar
Joined Mar 2012
We need a video!
-Andres
Old Apr 23, 2014, 02:52 PM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
the first thing i saw was no tiny pushrods or guides.
nice.
no more posts about "is my rod flexing too much?"
lol.
gotta check out the plane some more. just had to comment.
swampflyer is offline Find More Posts by swampflyer
Old Apr 23, 2014, 03:11 PM
Charlie Tilney is offline
Find More Posts by Charlie Tilney
Extreme Flight for the win
United States, CA, Portola Valley
Joined Aug 2013
Sub'd!!!! Can't wait!
Charlie Tilney is offline Find More Posts by Charlie Tilney
Old Apr 23, 2014, 03:12 PM
Joined Dec 2012
orange and green schemes show the same pic on the site...
just FYI...
Old Apr 23, 2014, 03:44 PM
Kooshball is offline
Find More Posts by Kooshball
Joined Jan 2014
Big improvement on all fronts. ..my only two complaints on the Crack Yak have both been addressed by this plane:
bending pushrods and lack of included landing gear
well done!
Kooshball is offline Find More Posts by Kooshball
Old Apr 23, 2014, 03:48 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Sweet! Subbed, get us a vid please Cody!
jimbo320 is offline Find More Posts by jimbo320
Old Apr 23, 2014, 03:56 PM
GoAround is online now
Find More Posts by GoAround
Can't fly 3D for toffee ...
United Kingdom, Taunton
Joined Dec 2012
This looks fantastic. I intend to get even more life out of the ex-Jimbo CY (for which I have slightly bent the motor shaft - sorry for being a careless owner Jim ) but when it dies, this will be the replacement. Like the CTB, I may buy ahead of time and store it ready to build.
GoAround is online now Find More Posts by GoAround
Old Apr 23, 2014, 04:01 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
John, you didn't? Oh well, never mind, hope you enjoyed it while it lasted!
I recently piled in my 39 inch sbach, unfortunately not even my custom heavy duty front end could save it from my dumb thumbs lol.
Once this comes over the pond, it's ordered!
Discussion Th 32" epp mxs-c cw flydynamics 3D Foamies 2 Apr 25, 2014 10:30 PM
Wanted Twisted Hobbys 32" EPP Crack Laser byoung Aircraft - Electric - Airplanes (FS/W) 2 Mar 04, 2014 12:11 PM
Poll Twisted Hobbys: 32" Crack Yak or Edge 540 enracer 3D Foamies 3 Dec 16, 2013 07:32 PM
Sold Twisted hobbies 32" laser lite with good equipment! Walker986 Aircraft - Electric - Airplanes (FS/W) 0 Dec 14, 2013 06:26 PM
Sold Twisted Hobbies Edge 540 32" EPP (LPU) Rich215 Aircraft - Electric - Airplanes (FS/W) 5 Oct 23, 2013 07:07 AM
