Old Feb 14, 2009, 10:59 PM
jp.electrik is offline
Find More Posts by jp.electrik
PunchDrunk ex-Pug try'n fly'n
jp.electrik's Avatar
Joined Jan 2009
BP-21 Lost can!
Any body ever had the outer can break loose on an outrunner?
jp
jp.electrik is offline Find More Posts by jp.electrik
Old Feb 15, 2009, 12:29 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
No. Good thing they are inexpensive.
http://www.bphobbies.com/view.asp?id...97&pid=U422859
The 3 wires are fragile and don't tolerate excessive movement.
I glue them with goop right at the base of the stator.
Here's a disassembly instruction
http://www.bphobbies.com/pdf/bp/BPMotorDisassembly.pdf
rick.benjamin is offline Find More Posts by rick.benjamin
Old Feb 15, 2009, 09:14 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
jp
I'm assuming you mean that the bell and shaft parted company... if they are held by set screws, then those may have come loose or fallen out... if the two are press-fitted together you may need to JB Weld them. The early CD ROM motors had that problem since the can was so thin that there was very little contact surface.
If the bell and shaft came out, that would be because the rear circlip failed.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 15, 2009, 10:54 AM
Joined Jan 2009
That's what I figure, problem is I have the motor glued to the firewall, not an easy extraction.
In a last ditch effort I fashioned a brace out of an old style mount. We'll try that today. I have my doubts, and a replacement motor.
jp
Discussion A lil old BP 21 can't hurt anyone........Don't bet on it!!!! randall1959 Flying Wings 30 May 07, 2006 02:12 PM
Discussion Can you shorten the shaft on a BP-21? deeman Power Systems 15 Apr 20, 2006 03:18 PM
Need Flying Wing that can use BP-21 Outrunner DD & 18 Amp BL ESC, Any recommends?? mrebman Flying Wings 3 Nov 01, 2005 01:15 PM
Can I run a gearbox with BP-21 foamie Electric Plane Talk 1 Jul 11, 2005 07:20 PM
BP 21 Brushless Outrunner CD Rom conversion? JREEVES Power Systems 0 Dec 11, 2004 05:31 AM
