Old Aug 03, 2004, 08:33 PM
Joined Jul 2004
what esc for shock flyer
what esc should i get when i buy an ikarus shock flyer. i want to be able to fly with a 10 cell NIMH battery while i save up for a li-poly battery and charger. i would also like to be able to use the esc with a 3 cell li-poly.
IraceaLosi is offline Find More Posts by IraceaLosi
Old Aug 03, 2004, 08:44 PM
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
If you are using the stock motor, a Pixie 7 from Castle Creations works well. It's what I use on the stock motor.
Cam
larsy87 is offline Find More Posts by larsy87
Old Aug 03, 2004, 09:12 PM
Eine melodie im wind
Buzzard's Avatar
North Carolina, United States
Joined Jun 2003
WOW 10 cells!!!!!!!!!!
It's gonna be way heavy
Typically most try and keep it under 7oz!
ONE hard landing with a 10 would most likley rip it apart!
IF you are gonna go BL get a CC10,Ya can't go wrong!
If you are gonna stay brushed and use lipos make sure you get a controller with Low voltage cut off(lvc)!!
Dahl
Buzzard is offline Find More Posts by Buzzard
Old Aug 04, 2004, 11:16 AM
Joined Jul 2004
if 10 cells would be too heavy, what NIMH battery should i use.
thanks
Old Aug 04, 2004, 06:11 PM
larsy87's Avatar
London, Canada
Joined Aug 2002
Nimhs and Nicds would be close in weight, nimhs would be a little lighter. Ikarus recomends 10 cells, so it shouldn't be that bad, but lipos would(3 cells) would make it fly a lot better. Try it on ten and then try it on lipos - you'll see a world of difference.
Cam
Best Brushless / Esc combo for Shock Flyer Extrema 330 Boo Foamies (Kits) 6 Mar 12, 2005 01:03 AM
what arethe best servos for a shock flyer? light ,fast and strong . wing warrior 3D Flying 7 Jun 20, 2004 02:45 PM
What esc for the AP-29 motor? Florin777 Electric Ducted Fan Jet Talk 7 Feb 27, 2003 05:40 PM
what esc for eco8 with stock motor and 10 cells campbell Electric Heli Talk 6 Jan 14, 2002 11:57 AM
What ESC for a Poppy (Soarstar)? BRAXX1 Foamies (Kits) 2 Oct 12, 2001 09:08 AM
