Old Dec 03, 2003, 03:35 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
Sturdyboard for micro models?
Hi everyone, I'm askinf for a JMP rx and accesories for Christmas and was wondering if stripped Stturdyboard would be suitable for these light weight models. it is about 3/16" when ready. It is quite lightweight, but would it be too thick for the tail feathers?
Bsmooth is offline Find More Posts by Bsmooth
Old Dec 03, 2003, 03:39 PM
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Just to give you a comparison, generally 1/32 contest balsa is used for the tail when balsa is used. I often use 2mm Depron for tail surfaces, and sometimes sand that down to 1mm. Weight is everything.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Dec 03, 2003, 03:43 PM
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
That is close to 5mm - much too thick (read heavy) for micro models IMHO. I would consider 3mm Depron too heavy for anything but the wings. Don't despair though, you can sand the foam thinner. I use a cheap oscillating sander for thinning down sheets.
Michael
epilot is online now Find More Posts by epilot
Old Dec 03, 2003, 03:46 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
I may still make a "universal" fuselage out of it so I may try different wing/tail configurations out of balsa wood. I really need a hotwire bow
what other materials are there that I could use (aside from balsa) to make micro tails/wings out of?
I do have acess to balsa and cf rod, but i'm just wondering what is commonly available (in the US )
Old Dec 03, 2003, 04:27 PM
Dan Leonard's Avatar
Lenexa KS USA
Joined Jun 2001
bsmooth
For your micro tail feathers go to grocery store and buy a package of styrofoam plates. Not trays. Round plates, the flat part should be large enough and only about 1-1.5mm thick. I think it's the Hefty brand that has the larger 10 inch. The always save brand is smaller but a little lighter foam. For less than three dollars you should be able to make fifty tail feathers. For the wings go to Depron USA and get a couple sheets of 2mm Depron and you should be set for the winter. If that doesn't work then wrap the 2mm depron around your favorite drink and serve lunch to your flying mates with the plates.
Dan
Dan Leonard is offline Find More Posts by Dan Leonard
Old Dec 03, 2003, 04:40 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
hey that is a good idea, well thought! I could probable even use it for wings if I made a four-panel polyhedral
Old Dec 03, 2003, 05:15 PM
Lenexa KS USA
Joined Jun 2001
You can try it for wings but it doesn't like to be rolled. It was heat crushed into the flat shape.
Dan
Old Dec 03, 2003, 06:20 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
I planned of using the heat gun to flex shape it
Old Dec 03, 2003, 07:49 PM
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
The sturdy board or art board seems close to depron.
Maybe you can hotwire cut some to 1mm or 2mm.
It might come out better shape than the foam plates as only the outer surface will have seen much heat. If you cut it quick enough maybe it will be good with a little sanding. I'm not sure though as I am a foam newbie.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Dec 03, 2003, 08:14 PM
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
You can also score (under side) the styro plates to make an airfoil shape. Just smear a bit of foam-safe CA glue over the score marks and hand-form or use tape to hold the shape until set. I have made several models this way including this one.
-John
Inari is offline Find More Posts by Inari
Old Dec 03, 2003, 08:59 PM
Backyard Bomber
Bsmooth's Avatar
Joined May 2002
Interesting model there Inari, is the fuselage made out of plate foam as well?
Old Dec 03, 2003, 11:00 PM
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
Yep, all Hefty foam plate: http://www.rcgroups.com/forums/showt...ghlight=barbar
Thrust test stand for micro models billystiltner Scratchbuilt Indoor and Micro Models 45 Jan 14, 2010 11:26 AM
Discussion Help me decide on equipment for micro models JoJa15 Scratchbuilt Indoor and Micro Models 8 Nov 15, 2006 09:39 PM
Looking to buy a radio for micro models... rickurukus Scratchbuilt Indoor and Micro Models 13 Sep 19, 2005 04:04 AM
Alert how to make actuator coils for micro models youth must fly Scratchbuilt Indoor and Micro Models 3 Jun 14, 2004 01:19 PM
Servo motors for micro models? Vonbaron Scratchbuilt Indoor and Micro Models 17 Jun 18, 2002 05:56 AM
