Old Jul 23, 2015, 04:40 AM
wojjow is offline
Find More Posts by wojjow
Joined Jul 2015
Help!
Jeti TF 2.4 Ghz transmitter, inputs
Hi,
I would like to know if can send ppm signal from my customized controller using Jeti TF 2.4 Ghz transmitter.
Could anybody help me with identifying inputs of this transmitter ?
wojjow is offline Find More Posts by wojjow
Old Jul 24, 2015, 08:24 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
!!! IF !!! this module case is a standard Futaba, then PPM is the rightmost, followed by:
- power pack plus
- unused, if grounded will tell to the radio that transmission is active
- ground
- unused, was connection for former FM antenna
Beware ! <- from right to left !!! <-
renatoa is online now Find More Posts by renatoa
Old Jul 24, 2015, 10:14 AM
JAyThaRevo is offline
Find More Posts by JAyThaRevo
Austria, Stmk., Graz
Joined Sep 2013
Did you check the manual?
If there is nothing in there just ask Jeti. They are pretty open to such technical questions.
If you get everything right, sure you will be able to transmit signals. But you will need a Jeti receiver on the other end. If that is ok with you...
JAyThaRevo is offline Find More Posts by JAyThaRevo
For Sale WL Toys 2.4 ghz , 4 ch Brick Receiver & Transmitter scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 May 19, 2015 05:14 PM
Wanted Phantom 2 transmitter 2.4 GHz - old version alek3d Aircraft - Electric - Multirotor (FS/W) 9 May 04, 2015 02:38 AM
Found EFLY 2.4 ghz or Art Tech 2.4 ghz transmitter jmdlcar Aircraft - General - Radio Equipment (FS/W) 1 Jun 30, 2014 06:41 PM
Sold Slightly uses HPI Racing TF-40 2.4 GHZ radio multiflyer2 Cars - Accessories (FS/W) 1 Dec 23, 2013 01:48 PM
Discussion Is it safe to use 2.4 GHZ Video Transmitter on Spektrum DSM2 2.4 GHZ ? lazy-b FPV Talk 2 Sep 04, 2010 10:28 AM
