Old Jul 12, 2015, 11:17 AM
John M.. is offline
Find More Posts by John M..
Spaceage Johnny
John M..'s Avatar
United States, FL, Clearwater
Joined Oct 2011
Brand new engine runs fine on starting table but quits when in air
I have a brand new ASP 25 (Hobby King cheepO). New Hayes fuel tank. Engine runs at WOT and at idle while on the starting bench at my flying field. I can let it run thru a whole tank on the bench with no problem. It will transition from idle to WOT fast or slowly. Sounds good - acts good on the ground.
When I get it up in the air I can get 1 or 2 laps around the field then engine sound changes to a lower pitch and then quits soon after. I have tried WOT, 1/2 throttle,
1/4 throttle. no luck, same result.
Also, have had several guys that I know who are pretty experienced, tune it, with same results.
Any ideas?
John
John M.. is offline Find More Posts by John M..
Old Jul 12, 2015, 11:45 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
The clunk in the tank should not be right at the back of the tank. It should be ahead maybe 3/8". Otherwise, I don't know, might need more pressure from the muffler, or just a bit richer? More breakin.
aspeed is offline Find More Posts by aspeed
Old Jul 12, 2015, 11:49 AM
John M.. is offline
Spaceage Johnny
John M..'s Avatar
Joined Oct 2011
clunk is about 1/4" with free movement. how would you get more pressure?
Old Jul 12, 2015, 12:31 PM
dmrcflyr2 is offline
Find More Posts by dmrcflyr2
dmrcflyr2's Avatar
United States, FL, Largo
Joined Feb 2006
Are you using a tachometer to set the high speed needle? If so, what RPM are you getting and setting it to? How many tanks of fuel do you have through it on the bench? It sounds to me like it is leaning out once in the air indicating you have it too lean on the ground.
dmrcflyr2 is offline Find More Posts by dmrcflyr2
Old Jul 12, 2015, 12:47 PM
1QwkSport2.5r is offline
Find More Posts by 1QwkSport2.5r
Performance Enthusiast
1QwkSport2.5r's Avatar
United States, MN, Cottage Grove
Joined Dec 2014
If there is a cowl on the plane, try flying with the cowling removed and see if that changes anything. If the engine isn't cowled, it's likely just too lean. New engines should be ran a bit richer for awhile until they break-in good. Some engines take awhile to break-in and until this happens, they will run a little hotter since they're often a bit tight when new.
1QwkSport2.5r is offline Find More Posts by 1QwkSport2.5r
Old Jul 12, 2015, 01:59 PM
John M.. is offline
Spaceage Johnny
John M..'s Avatar
Joined Oct 2011
I've only had 1 tank - 6oz. thru it. no cowl and I don't have a tach. I'm going to set rich, or more rich and fly it this evening after the wind dies, which should be around 7pm eastern - it is way to hot n windy right now.
thanks for your replies.
John
Old Jul 12, 2015, 02:05 PM
dmrcflyr2's Avatar
Joined Feb 2006
One tank? How is that enough to judge whether or not it runs right on the bench? It hasn't even begun to be broken in yet. What prop size are you running? Are you following the instructions for breaking the engine in?
http://media.hobbypeople.net/manual/210630.pdf
Old Jul 12, 2015, 05:24 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
The hole in the pressure fitting could be on the small side, and the outlet hole of the pipe can be reduced. I think it is just too lean and not broken in yet. I have had to run motors on backplate pressure when the carb hole is too big for good suction. A regulator may be needed with a throttle.
Old Jul 13, 2015, 04:47 AM
John M.. is offline
Spaceage Johnny
John M..'s Avatar
Joined Oct 2011
yesterday evening I set her way rich - more than 4 turns out, it flew pretty good.
Thank for all your replies
John
Discussion 3DR telem; air & ground modules run at different baud rates but the same air rate? Cereal_Killer Multirotor Electronics 5 Jun 28, 2015 09:10 PM
Discussion Buggy runs fine on LiPo but not on LiFe battery shesmer Electric Power Cars 7 Jan 04, 2015 07:28 PM
Question Can a model gas engine start on it's own from a spark when ignition is turned on ???? shooboy Engines 95 Dec 21, 2014 02:52 AM
Discussion Motor runs on 3s fine, but not on 2s High Flyin' Power Systems 6 Jun 09, 2014 07:24 AM
Motor won't start, but will run when flipped ham2405 Power Systems 18 Aug 14, 2005 10:50 PM
